Ethernet doesn't have a valid IP configuration
jamiesmith058
Hello I keep having this ongoing issues where my network would completely drop and im not sure what is going wrong,
I have a Virgin hub 3 in modem mode connected to one router and the router to a range extender through wifi.
the issues affects the wired clients the same but some of them are able to come back online whilst others connected by an ethernet connection say Ethernet doesn't have a valid IP configuration.
I have tried all the netsh winsock reset to ipconfig release and renew, sometimes when completing ipconfig /renew it states the ip is already in use.
but the only thing that seems to fix it is to reset hub 3 and router to default settings.
I have ruled out the router as i have just changed from TP-Link Archer A7 AC1750  to TP-Link WiFi 6 OneMesh Router, AX1500
There has been some errors in the hub 3 error logs, if anyone has any idea on how to resolve this would appreciate it!
16/10/2024 00:39:58noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:44criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/10/2024 00:09:50noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/10/2024 18:28:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2024 09:08:3ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2024 04:09:3criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/10/2024 20:05:58noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/10/2024 20:05:41Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/10/2024 20:03:34noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/10/2024 20:00:41criticalTLV-11 - Failed to set duplicate elements;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/10/2024 19:57:51noticeUnit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2024 11:15:21noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/10/2024 18:51:45ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/10/2024 17:37:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2024 06:51:45ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/10/2024 10:10:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/09/2024 03:43:10ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/09/2024 23:55:13noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13 REPLIES 13
I see so this was happening before the new router.
cables that come with routers are cheap suggest better ones
1aTTack.de 3 meter Cat6 Ethernet Cable Lan Patch Cat 6 Cables Internet Rj45 Plug 1Gbit/s SFTP PIMF -...
DIGITUS CAT 6 S-FTP patch cord, Cu, LSZH AWG 27/7, length 3 m, color grey : Amazon.co.uk: Computers ...
setup a BQM to your new router
Broadband Quality Monitor | thinkbroadband
do you have HomePlug - Network Via Mains?
That all looks fine. I can only suggest you start by disconnecting all your devices, and rejoin them one at a time, until you get the loss of IP.  This may identify a "rogue" device causing the issue, e.g. managed switch ?  I doubt if it is the Hub, as in modem mode it's only a "bridge" between VM and your TP-Link and has no other functions available.
Thanks for the advice ill keep a close eye on it as it doesnt happen all the time ive disconnected the range extender as that was the newest item on the network but unsure what can cause these issues in the first place
ill look at swapping the ethernet cables out but im sure none of them were what came with the devices i bought new ones think they are cat 5e and i did have a range extender connected but i have disabled that for now because thats the only item in the network that has been added in the year
