bobthecooldude
Just browsing
Ethernet connection..
Do I have to keep V6 box connected to hub by ethernet cable.Hub is about 16 feet from the hub and wife doesn't want cable to be connected all the time.Can I not just connect the ethernet cable every now and again to check for updates ? ..Cant connect by WIFI as I presume hub is too far from the V6 box to connect.
  • 18.71K
  • 1.63K
  • 4.07K
Re: Ethernet connection..
don't think it needs to be attached 24/7, rather than having cable running around you could use a pair of homeplugs so data travels using the internal power cables, would check to see what sort of signal quality you get using the V6 wifi.
bobthecooldude
Just browsing
Thanks for the help.
