Jammidge
Ethernet connection not working
Hi, been watching Prime/Netflix on a TV (in a different room to media box and modem) using WiFi but signal has got really bad.
I bought 2x Netgear PL1000’s and an Amazon Ethernet adapter to hard wire the tv to internet. However in the Networking section on Prime it cannot find the wired connection and only proposes wifi!
I have tried connecting the Netgear to both the media box and modem but it doesn’t change anything. On YouTube, it looks really simple but clearly I am doing something wrong!
any ideas?
  • 132
  • 10
  • 28
Tsar
Superfast
Re: Ethernet connection not working
What's the "media box"? Is it an Amazon firestick? Is it a first generation firestick ie without the speech recognition on the remote?
  • 11.7K
  • 347
  • 678
Forum Team (Retired) Samantha_L
Hi there Jammidge,
Thanks for taking the time to post on the community and apologies for any inconvenience caused.
If you are trying to connect your TV to the router through Ethernet, you will need to go into the TV settings to change that over rather than on Prime.
What do you mean about Amazon Ethernet adapter?
To connect the powerline adaptors to the router, you can try the WPS button.
I hope this is what you are trying to do. If you need any more help, by all means post back here.
Sam
