hotspots
Ethernet connection drops suddenly
Hi there,
I've recently had the 350mb Internet and Phone package installed. I've got various devices using this, with my main computer that I use for Gaming and Work being connected via Ethernet (Gigabit Network card). I've noticed that the Ethernet drops and it goes back to WiFi for between 5-10 seconds, then switched back as Ethernet connects again. It's very strange as this doesn't seem to happen via Wifi, and I've never had this with my previous provider (Sky).
To make matters even stranger, having checked older forum posts I've gone into my Routers admin to check the Router Status and found that there are recorded dropouts referencing the error code:
"No Ranging Response received", which coincide with the Ethernet dropouts I receive.
Here's the log:
Cable Modem Status
Item Status Comments
155000000
Locked
Ranged Upstream Channel (Hz)
39400002
Locked
Provisioning State
Online
1 155000000 6.3 38 256 qam 3
2 139000000 6.1 38 256 qam 1
3 147000000 6.3 38 256 qam 2
4 163000000 6 38 256 qam 4
5 171000000 5.9 38 256 qam 5
6 179000000 5.8 38 256 qam 6
7 187000000 5.5 38 256 qam 7
8 195000000 5.3 38 256 qam 8
9 203000000 5 38 256 qam 9
10 211000000 4.6 38 256 qam 10
11 219000000 4.6 38 256 qam 11
12 227000000 4.3 38 256 qam 12
13 235000000 3.9 38 256 qam 13
14 243000000 3.7 38 256 qam 14
15 251000000 3.2 38 256 qam 15
16 259000000 2.5 38 256 qam 16
17 267000000 3 38 256 qam 17
18 275000000 4 38 256 qam 18
19 283000000 5.3 38 256 qam 19
20 291000000 5.3 38 256 qam 20
21 299000000 5.5 38 256 qam 21
22 307000000 5 38 256 qam 22
23 315000000 4.9 38 256 qam 23
24 323000000 5.4 38 256 qam 24
1 Locked 38.9 32 0
2 Locked 38.9 13 0
3 Locked 38.9 35 0
4 Locked 38.9 33 0
5 Locked 38.6 43 0
6 Locked 38.6 32 0
7 Locked 38.6 38 0
8 Locked 38.6 32 0
9 Locked 38.9 19 0
10 Locked 38.6 26 0
11 Locked 38.9 22 0
12 Locked 38.9 32 0
13 Locked 38.9 31 0
14 Locked 38.9 24 0
15 Locked 38.9 38 0
16 Locked 38.9 46 0
17 Locked 38.9 59 0
18 Locked 38.9 23 0
19 Locked 38.9 18 0
20 Locked 38.6 13 0
21 Locked 38.6 23 0
22 Locked 38.9 20 0
23 Locked 38.9 27 0
24 Locked 38.9 30 0
1 39400002 4.575 5120 16 qam 10
2 25799991 4.425 5120 16 qam 12
3 32599998 4.575 5120 16 qam 11
4 46200031 4.575 5120 16 qam 9
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
oA,.iyewrkldJKDHSUBsgvca69834ncxv98
SFID 2518
Max Traffic Rate 402500089
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 2517
Max Traffic Rate 38500089
Min Traffic Rate 0
Max Concatenated Burst 42600
Scheduling Type
BestEffort
06/09/2019 05:53:48 critical No Ranging Response received - T3 time-out;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
09/09/2019 22:26:8 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
09/09/2019 22:32:32 critical TFTP failed - Request sent - No Response;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
09/09/2019 22:32:32 critical TFTP Request Retries exceeded, CM unable to register
09/09/2019 22:36:21 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
09/09/2019 22:36:24 critical TFTP failed - Request sent - No Response;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
09/09/2019 22:36:24 critical TFTP Request Retries exceeded, CM unable to register
10/09/2019 15:10:22 critical No Ranging Response received - T3 time-out;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
Any ideas? Any help would be hugely appreciated. My current guestimate is the Hub needs replacing or the cables running to my house haven't been configured correctly.
  • 5.9K
  • 453
  • 990
Hero
Re: Ethernet connection drops suddenly
Stats are fine. The T3’s errors are bad, usually cause by noise on the circuit. Try calling customer services to see if there is a problem in your local area. It will not appear on the VM status page if there is.
There are 10 types of people: those who understand binary and those who don't and F people out of 10 who do not understand hexadecimal
hotspots
Hi Tudor, thanks for replying. Would the T3 errors usually affect Wifi as well, as I've not seen any issues with that, just with Ethernet.
  • 1.13K
  • 158
  • 474
Andruser
Knows their stuff
Since T3 (and similar) errors affect your cable connection, they would certainly affect wifi.  But because wifi is both a slower, but more fault tolerant protocol than the DOCSIS cable technology you'd possibly be less likely to notice momentary interruptions.  But Windows will notice when it loses an internet connection, and then you'd potentially have to wait for it to reset the PC's network adaptor.
You might want to set up a Broadband Quality Monitor over at thinkbroadband.com let it run for a few days and see what that shows.  An example is my BQM (below) which is for a connection that's usually pretty solid, but you'll see the red spike of significant packet loss around 8pm that indicates a momentary loss of internet connectivity between the thinkbroadband server and my hub.
My Broadband Ping - VM number 2
