on 06-05-2022 11:32
Hi, I have an Ethernet cable run to my home office in the garden but please can someone advise me what to plug into the Ethernet port to get a wireless signal in the office?
on 08-05-2022 15:38
Hi, I got a TL-WA901N
ive spent days trying to figure this out, surely it shouldn’t be this difficult??!!
Please help!
on 08-05-2022 15:47
on 08-05-2022 16:03
No I haven’t, all our laptops don’t have an Ethernet port hence why I need wireless! Any suggestions on how I can test the Ethernet?
on 08-05-2022 16:14
@KEF wrote:No I haven’t, all our laptops don’t have an Ethernet port hence why I need wireless! Any suggestions on how I can test the Ethernet?
borrow a laptop with an ethernet port of buy a cable tester - a few quid on ebay a bit more at screwfix or the like
08-05-2022 16:15 - edited 08-05-2022 16:19
Yes... do what I do on all of my Apple devices... get a port<->ethernet adapter and plug it into whatever port the laptops have and then plug in the office cable.
I have them for USB3, USBc, Thunderbolt, Firewire and lightning ports - and all connect just fine on my Mac's.
Or use a gaming console if you have one.
Here is an example - although never used this one so its not a recommendation 🙂
https://www.amazon.co.uk/MARSPOWER-Ethernet-Network-Multifunction-Portable/dp/B094NV6VMC/
on 08-05-2022 17:55
This page has a video of how to setup the TP-Link in Access Point mode
Download for TL-WA901N | TP-Link United Kingdom
You can do all this sitting beside the VM Hub and move the TP-Link back into the garden room when your have finished the setup.
on 08-05-2022 19:23
Brilliant thank you! I’ve plugged the tp link into the VM Hub to set up and I’m getting the same message so it must be something to do with the settings. I haven’t amended any of them, I’ve just gone with the default settings.
When I try to connect I get a blue tick saying it’s connected but then I get a message underneath in orange saying “No Internet Connection”.
Any ideas?!
on 08-05-2022 19:36
Also, having just checked, I’ve got a Hub 3 - does that make any difference? Sounds like there are much more updated ones out there?
on 08-05-2022 19:46
cannot help with the setup but it should work with a hub3
on 08-05-2022 19:47
