on 17-06-2021 19:48
Hi I am unable to get my MAC to connect to the hub via cable. Do Virgin supply the IP address? The MAC response seems to suggest it should. Any ideas will be gratefully received.
Sal
Answered! Go to Answer
on 20-06-2021 15:57
The issue is that your device has an IP address that is on a different network to the Hub. Can you test from another device like a phone or another PC.
on 20-06-2021 16:16
Thank you, I think it has been cracked.
Could I thank you all for your help.
kind regards
sal
on 20-06-2021 19:27
@salkhan1409 wrote:Thank you, I think it has been cracked.
Could I thank you all for your help.kind regards
sal
What was the fix?
on 21-06-2021 06:37
I got the IP address from the hub and changed the one on the mac.
Thanks Sal
