paulmanalishi
Endless Hub 3 Issues, Restarts, Drops. Fed up.
Hi Everyone
switched from slow local BT broadband (no plans for fibre where I live and I live in a fairly built up area which I just can’t understand) to ultra fast 200 Virgin fibre (with Sky Q tv).
It started ok but now haven’t frequent issues around the router seemingly just restarting itself over and over again.
Ive tried various things including renaming the SSID’s for 2.4 and 5 GHz but to no avail.
Admin log shows many many ‘critical’ issues of which I don’t understand:
 And here’s other info the router is currently displaying:F351E5EF-2A7F-4B8E-9361-C018CD3441B4.jpeg
Desperate for help. Wondering whether putting a third party router on it and using it in modem mode would help but not convinced it would. I love fast broadband but I’d much rather have a reliable broadband of a lower speed frankly!!!
thanks everyone
Paul
  • 6.24K
  • 670
  • 971
Hero
Re: Endless Hub 3 Issues, Restarts, Drops. Fed up.
Try doing a pinhole reset to factory settings. Push the pin on the hub with the end of a paperclip in until you feel its its stop point and hold for a "timed" 40 seconds do NOT restart the router after that. Your passwords/passphrase for both Hub and Wifi will revert to those printed on the Hub sticker on its base/side/drawer.
paulmanalishi
Thank you but already done that twice...
  • 6.24K
  • 670
  • 971
Hero
If its restarting over and over and the pinhole does nowt, it's faulty. Call it in and ask for a replacement Hub that actually works.
paulmanalishi
Ok I will do so would you know if any of the info I posted looks odd or does it sound like a hardware issue only? Cheers
  • 6.24K
  • 670
  • 971
Hero
I am still only seeing yellow triangles. Usually means that the Mods have not approved the shots yet - but could be me needing a cache clearout Sorry- But I not the expert in the "errors" area anyway.
