rossvalentine19
Message 1 of 5
Download speed is so slow
hi there im just wondering if anyone can help my download speed is honestly so slow for the package i have and i have no idea why it goes from 22mb/s down to 2mb/s the 0mb/s and its really frustrating can anyone help ?
sophist
  • 2.55K
  • 420
  • 683
Message 2 of 5
Re: Download speed is so slow
how are you testing the speed? from a wired device or over wireless? if the latter, you need to conduct the test using a device that is cabled into the router over ethernet..
rossvalentine19
Message 3 of 5
yeah its my Pc its hooked up to the modem via the ethernet cable and the download speed is ridiculously slow ive ran a speed test and its says its fine but its taking hours for simple things to down load
sophist
  • 2.55K
  • 420
  • 683
Message 4 of 5
ok, so next steps are to set up a BQM - once set up, find the Live Graph and click "Create Sharing Link" - post that back here.
Next, browse to your hub on  http://192.168.0.1 - don't log in, click Router Status - copy/paste the tables from the Upstream, Downstream and Network Log tabs back to this thread - you'll need multiple posts for this, the info wont all fit into a single one..
Paulina_Z
  • 1.11K
  • 34
  • 69
Message 5 of 5
Hi @rossvalentine19,
Welcome to our Community Forums! Thank you for your post, and I'm sorry to hear that you're experiencing slow speeds on both wired and WiFi connections!
Can you update us on this issue and let us know if you've set up a BQM chart to monitor your connection as suggested by @sophist?
I was able to locate your account and run through some checks for you. I can see that you're having some downstream connection issues. A technician will be needed to look into this issue further.
I will send you a Private Message to confirm a few details with you before I can book the technician. Please keep an eye out for a purple envelope at the top right corner of your Forum page.
I will be in touch soon. 🙂
Paulina_Z
