on 04-07-2022 21:55
So i have the 1gb package and from day 1 i dont ever receive what im paying for ethernet or wireless does not matter my hub gets it but i dont.
for example this is my phone and this is similar to what i get on my wired pc. Question is why is this? Also would a separate router help improve my speed both wired and wirelessly.
thanks
on 04-07-2022 22:12
Thats the maximum speed the hub4 can realistically do over wifi as its only wifi5 not the latest wifi6
on 04-07-2022 22:22
What about ethernet?
on 04-07-2022 23:37
The Hub4 should give you 940M on an Ethernet cabled device. I run mine in modem mode with a Ubiquiti Dream Machine Pro router. Check your cables.
Speedtest by Ookla
Server: Lightning Fibre Ltd - London (id = 34931)
ISP: Virgin Media
Latency: 9.07 ms (0.31 ms jitter)
Download: 939.81 Mbps (data used: 1.2 GB)
Upload: 52.32 Mbps (data used: 26.3 MB)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/4b08ba26-63c2-4686-88e7-17ea46628c05
on 05-07-2022 07:56
Brought new cat 6 cables so I know its not them tried 2 different pcs both no where near thr 1gb and i may have to try a new router then. Hmm..
