on 05-06-2023 15:25
Hi there,
We had our fibre installed at our business last week (after 6-month wait).
The incoming connection is good and devices are connected to it - however they don't seem to be able to see each other or communicate with each other
For example, laptop cannot see wireless printer on the same network - we are a hospitality business which uses point of sale on ipads, and the ipads can't see each other
Help very much appreciated
on 05-06-2023 15:47
Sounds like you need to contact VM Business https://www.virginmediabusiness.co.uk/help-and-advice/existing-customers/customer-area/
on 05-06-2023 16:12
Yeah have tried that and not much help so far. Don't get much further than 'there is internet coming in, everything else is your problem'
on 05-06-2023 16:39
As a guess when trying to connect to a printer try and ensure both laptop and printer are on the same frequency (eg 2.4 GHz). Splitting frequencies can help with this.
on 05-06-2023 16:42
Check the IP address of the devices and printer, all should be on the same subnet for communication to would. The nnn.nnn.nnn part of the IP address shod be the same.
on 05-06-2023 17:14
Thanks, is there a router setting that would put everything on one subnet?
on 05-06-2023 18:18
Are you seeing IP across 2 subnets E.g. 192.168.0.xxx and 192.168.1.xxx ?
You mentioned business, which Hub do you have ? It is a Residential Hub 3/4/5 or a Hitron model ?
Domestic Hub's do not have any way to control the DHCP ranges on 2.4 / 5 Ghz.
on 06-06-2023 08:35
Thanks, I can see that all the connected devices are on different IP addresses, trying to work out the setting that changes that.
It's a CHITA router
on 06-06-2023 09:04
We see domestic Hub 5 customers report the WiFi devices connected on the 2.4 and 5 Ghz bands can not contact each other. E.g. A laptop on 5GHz can not ping or print to a WiFi printer on the 2.4Ghz band.
Could this also be the same situation you have with the Hitron ?
The fix for this is to add a dual band WiFi access point or use a 3rd Party WiFi Router that can be configured with AP isolation disabled on both 2.4 & 5Ghz to enable the traffic to pass between devices on the WiFi bands.
on 06-06-2023 09:09
Everything's connected to the 2.4Ghz connection - so essentially we can't use this a wifi router?
Thanks for the help it is appreciated
