  • 14
Devices not switching to 5ghz
I have a hub 3 and having issues getting devices to switch to the 5ghz broadcast. I have many devices connecting at the same time so 2.4 ghz is very slow or disconnects other devices.
Settings are all auto in hub as delivered. Wifi analyser app shows nothing nearby using any channels near mine.
Used the scan house wifi in Virgin app which sorted the issue and gave me 200mbs to phone, left the house and came back. Now back on 2.4 and getting 20 download 21mbs upload
Tags (1)
  • 25.02K
  • 1.44K
  • 3.19K
Re: Devices not switching to 5ghz
Separate the WiFi bands and manually connect to the 5Ghz one
  • 12
Settling in
How do you seperate the wifi bands?
  • 12.15K
  • 943
  • 1.56K
Best done with a cable connected device.
Instructions for Hub 3
Log in to the Hub.
Advanced Settings > Wireless > Security > Add 2 to the 2.4GHz Channel name [SSID] > Add 5 to the 5 GHz Channel name [SSID] > Click ‘Apply Changes’
Log out of the Hub then reboot using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your Wi-Fi again.
You will need to reconnect all you Wi-Fi devices some will want to connect to 5Ghz and some to 2.4GHz and some will connect to either.
When you connect the devices do it at the furthest point from the Hub that the device will be used.
Mike Robinson
