on 19-12-2022 22:21
I have devices connected by wifi and by ethernet cable. At least one computer that I can verify is connected (available via ssh) but is not listed in the modem's connected devices.
The local IP is not listed (it ends 18) but several others appear, including a laptop connected twice (wifi and ethernet).
Any clue why an ethernet-connected computer might not be visible? Could it be the device's firewall or would that not affect this?
It's not a huge issue as port-forwarding still works and there are other ways for me to get the local IP, but I'd like to know the answer if anyone can tell me.
on 19-12-2022 23:34
on 19-12-2022 23:47
Hi Captain Snarky Comments
I think you know I meant the hub, no need to be condescending
The device used to be listed and now it's not. The hub knows what every single device is that connects by their network name. One connected device isn't appearing in the list of connected devices.
on 20-12-2022 00:44
on 20-12-2022 09:49
Okay no worries, thanks for your reply. M
on 22-12-2022 10:02
Hi there @mikechalmers
I am so sorry to hear that you are facing this issue with your listed devices, just to confirm was this showing previously but the device has now disappeared?
Thanks again
on 22-12-2022 10:40
Hi @Ashleigh_C - that is correct, device used to be visible in connected devices but now is not.
I thought it might have been due to the firewall on the device, but I disabled it and it still doesn't show on the hub admin.
The device itself has internet connection (via ethernet directly to the hub) and has a local IP, so it's not a huge deal but it's a little inconvenient and I also would rather see all the connected devices to properly manage the network rather than just some devices.
There's a possibility other devices don't show, but it was only because I was looking for this one to directly connect to it that I discovered it wasn't appearing on the connected devices.
on 22-12-2022 14:17
The VM hubs are not designed for users to manage their LAN network. If you want to do proper network management you need to get your own network equipment, as many users on the board have done.
