on 13-08-2022 18:38
Having some gardening work done at the moment and the virgin cable has been damaged in the process.
The cable was essentially on the surface.
How do I report this? Tried calling the number but wasn't sure which options to pick.
Thanks in advance
on 13-08-2022 20:14
You report it as a fault.
Call Customer Services on 0345 454 1111/150 if you have a VM landline or wait two or three days for a VM staff member to get to your post.
on 16-08-2022 13:27
Hi M_shears1988,
Thank you for your post.
Upon checking the system I can see that you've been able to reach the team and an engineer has been booked for you. Please keep us posted on the outcome of the visit.
Cheers,
Ryan.
