on 14-11-2022 07:08
Curious to know if anyone else has experienced these issues - in SW London in particular and has any solutions?
Broadband has largely been fine for many years, however back in Sept in SW London we've had no end of issues. My broadband is going down 2-10 times per day and only returning after a router reboot. On bad days I simply give up restarting and work using mobile data so not clear to me what the upper bound of restarts is.
Virgin did 'upgraded' me to super-hub 3 which may have anecdotally reduced the frequency of reboots, but on a good day it's still at least twice per day.
When I run the usual Virgin service check I usually get a notification the following notification:
However, when I speak to support, they either feign ignorance or simply ask me to restart/try again later. This has been going on since 20th September. I'm not sure whether it's now at a point where I simply have to end my agreement and/or whether anyone else will be any better.
No engineer has been around despite over 20 calls to Virgin over this period. To be fair, most days I simply can't hang around for extended periods trying to speak to someone in support. I was also told as my broadband is working for even a short period each day I am not entitled to any compensation.
My only short term fix is adding a remote powered restart switch so I can reboot my router remotely. But it's still a pain when all my smart devices expect to be connected 24x7.
on 14-11-2022 10:05
Please post some stats:
How to get stats from a VM hub (no need to logon to the hub)
Open a web browser and go to 192.168.0.1 router mode or 192.168.100.1 modem mode
on 14-11-2022 13:15
Channel | Frequency (Hz) | Power (dBmV) | SNR (dB) | Modulation | Channel ID |
1 | 171000000 | 9 | 40 | 256 qam | 5 |
2 | 139000000 | 10.1 | 40 | 256 qam | 1 |
3 | 147000000 | 9.9 | 40 | 256 qam | 2 |
4 | 155000000 | 9.4 | 40 | 256 qam | 3 |
5 | 163000000 | 9.1 | 40 | 256 qam | 4 |
6 | 179000000 | 9 | 40 | 256 qam | 6 |
7 | 187000000 | 9.1 | 40 | 256 qam | 7 |
8 | 195000000 | 9.1 | 40 | 256 qam | 8 |
9 | 203000000 | 8.9 | 38 | 256 qam | 9 |
10 | 211000000 | 7.4 | 38 | 256 qam | 10 |
11 | 219000000 | 7.9 | 38 | 256 qam | 11 |
12 | 227000000 | 8.6 | 38 | 256 qam | 12 |
13 | 235000000 | 8.8 | 38 | 256 qam | 13 |
14 | 243000000 | 8.5 | 38 | 256 qam | 14 |
15 | 251000000 | 8.4 | 40 | 256 qam | 15 |
16 | 259000000 | 8.3 | 38 | 256 qam | 16 |
17 | 267000000 | 8.6 | 38 | 256 qam | 17 |
18 | 275000000 | 9.3 | 38 | 256 qam | 18 |
19 | 283000000 | 9.3 | 38 | 256 qam | 19 |
20 | 291000000 | 9 | 38 | 256 qam | 20 |
21 | 299000000 | 8.8 | 38 | 256 qam | 21 |
22 | 307000000 | 8.4 | 38 | 256 qam | 22 |
23 | 315000000 | 8 | 38 | 256 qam | 23 |
24 | 323000000 | 7.6 | 38 | 256 qam | 24 |
Channel | Locked Status | RxMER (dB) | Pre RS Errors | Post RS Errors |
1 | Locked | 40.3 | 0 | 0 |
2 | Locked | 40.9 | 4 | 0 |
3 | Locked | 40.3 | 5 | 0 |
4 | Locked | 40.3 | 6 | 0 |
5 | Locked | 40.9 | 4 | 0 |
6 | Locked | 40.3 | 5 | 0 |
7 | Locked | 40.3 | 5 | 0 |
8 | Locked | 40.9 | 3 | 0 |
9 | Locked | 38.9 | 4 | 0 |
10 | Locked | 38.9 | 0 | 0 |
11 | Locked | 38.6 | 4 | 0 |
12 | Locked | 38.9 | 6 | 0 |
13 | Locked | 38.9 | 4 | 0 |
14 | Locked | 38.9 | 6 | 0 |
15 | Locked | 40.3 | 4 | 0 |
16 | Locked | 38.9 | 0 | 0 |
17 | Locked | 38.9 | 5 | 0 |
18 | Locked | 38.9 | 4 | 0 |
19 | Locked | 38.9 | 3 | 0 |
20 | Locked | 38.9 | 4 | 0 |
21 | Locked | 38.9 | 6 | 0 |
22 | Locked | 38.6 | 6 | 0 |
23 | Locked | 38.6 | 6 | 0 |
24 | Locked | 38.9 | 6 | 0 |
Channel | Frequency (Hz) | Power (dBmV) | Symbol Rate (ksps) | Modulation | Channel ID |
1 | 36600000 | 39 | 5120 | 64 qam | 3 |
2 | 23600000 | 37.5 | 5120 | 64 qam | 5 |
3 | 30100000 | 39 | 5120 | 64 qam | 4 |
4 | 43100000 | 39 | 5120 | 64 qam | 2 |
5 | 49600000 | 41.5 | 5120 | 64 qam | 1 |
Channel | Channel Type | T1 Timeouts | T2 Timeouts | T3 Timeouts | T4 Timeouts |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
5 | ATDMA | 0 | 0 | 0 | 0 |
Time | Priority | Description |
14/11/2022 12:56:33 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/11/2022 12:41:56 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/11/2022 12:41:56 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/11/2022 12:11:57 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/11/2022 12:11:57 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/11/2022 11:41:56 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/11/2022 11:41:56 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/11/2022 10:55:56 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/11/2022 12:48:49 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/11/2022 10:34:28 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/11/2022 10:33:34 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/11/2022 10:32:49 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/11/2022 10:32:22 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/11/2022 23:26:16 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/11/2022 14:28:47 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/11/2022 14:28:47 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/11/2022 14:28:42 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/11/2022 14:28:42 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/11/2022 14:27:28 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/11/2022 14:27:28 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 16-11-2022 15:13
Hi RahimC,
Thanks for posting and welcome to our community 🙂
Sorry to see you've had some issues with your connection.
I've not been able to locate any details for you from here, so I've popped you over a private message (purple envelope top right hand corner) to get a few more details from you.
Alex_Rm
on 22-11-2022 13:31
Thanks. The issues seem to have been resolved with no action my end, so assume that whatever intermittent works or issues that have been going on since September are now resolved. Fingers crossed this is the end of it.
on 24-11-2022 13:36
Thank you for letting us know this seems to have been resolved for you now @RahimC
Please let us know if you are having any further issues or have any questions at all. We'll be here to help on the community forums if needed :).
