on 30-08-2021 10:37
Hello
I feel like this will be a long term issue so making a post here.
Background - I've joined VM just over 2 months ago and was given a Hub 4. I've had no Issues at all until the planned maintenace in my area(16th and 18th Aug).
Since then I've had approximately 2 daily full on disconnections (a hub restart to fix). First one usually happens at 9:30, and second one around 16:00 during work days. This is especially annoying as me and my partner had multiple meetings interrupted because of it.
On top of the disconnections, I have been noticing minor packetloss during my gameplays and managed to catch them on pingplotter, as well as ThinkBroadband. Note the minor packet loss on top of the graph (https://www.thinkbroadband.com/broadband/monitoring/quality/share/fc5e009c05aa70cce0886bb313503987af...)
I have hub 4 connected to ASUS router, and my PC is connected via ethernet and all other devices are connected via WIFI. When disconnection happens, all of them will drop out, including my phone which I manually connect to the VM Hub to ensure that its not the ASUS routers problem.
I've called the customer helpline twice but all they offered was to restart the hub and as my internet connection was considered "connected" they couldn't offer any more help.
I've also called 0800 561 0061 just now to check for local area fault, and there aren't any.
Please shed some light on this situation, and please let me know if any logs needs to be uploaded for further diagnostics.
on 30-08-2021 15:10
on 30-08-2021 16:08
Thanks for the reply
The last known disconnection was yesterday morning 29/08. I've started the BQM from 4pm onwards and not had a full-on disconnect since then. Ping plotter is showing minor but consistent packet loss still
As for your proposed experiment. I will unplug my router from the VM Hub tonight see if anything changes by tomorrow morning
I think there are some logs so here they are
3.0 Downstream channels
25 | 331000000 | 10.1 | 40.4 | QAM256 | 25 |
1 | 139000000 | 12.4 | 40.9 | QAM256 | 1 |
2 | 147000000 | 12.4 | 40.4 | QAM256 | 2 |
3 | 155000000 | 12.2 | 40.4 | QAM256 | 3 |
4 | 163000000 | 12.1 | 40.4 | QAM256 | 4 |
5 | 171000000 | 11.7 | 39 | QAM256 | 5 |
6 | 179000000 | 11.7 | 40.9 | QAM256 | 6 |
7 | 187000000 | 11.4 | 40.4 | QAM256 | 7 |
8 | 195000000 | 11.6 | 40.9 | QAM256 | 8 |
9 | 203000000 | 11.4 | 40.4 | QAM256 | 9 |
10 | 211000000 | 11.1 | 40.4 | QAM256 | 10 |
11 | 219000000 | 10.8 | 40.4 | QAM256 | 11 |
12 | 227000000 | 10.8 | 40.4 | QAM256 | 12 |
13 | 235000000 | 10 | 40.4 | QAM256 | 13 |
14 | 243000000 | 9.7 | 40.4 | QAM256 | 14 |
15 | 251000000 | 9.6 | 39 | QAM256 | 15 |
16 | 259000000 | 9.8 | 40.4 | QAM256 | 16 |
17 | 267000000 | 9.1 | 40.4 | QAM256 | 17 |
18 | 275000000 | 10.7 | 40.4 | QAM256 | 18 |
19 | 283000000 | 10.5 | 40.4 | QAM256 | 19 |
20 | 291000000 | 11 | 40.4 | QAM256 | 20 |
21 | 299000000 | 10 | 40.4 | QAM256 | 21 |
22 | 307000000 | 10.1 | 40.4 | QAM256 | 22 |
23 | 315000000 | 9.7 | 40.9 | QAM256 | 23 |
24 | 323000000 | 10.2 | 40.4 | QAM256 | 24 |
26 | 339000000 | 10.5 | 40.4 | QAM256 | 26 |
27 | 347000000 | 10.4 | 40.4 | QAM256 | 27 |
28 | 355000000 | 10.2 | 40.9 | QAM256 | 28 |
29 | 363000000 | 9.5 | 40.4 | QAM256 | 29 |
30 | 371000000 | 9.7 | 40.9 | QAM256 | 30 |
31 | 379000000 | 10.1 | 40.4 | QAM256 | 31 |
on 30-08-2021 16:09
25 | Locked | 40.366287 | 0 | 0 |
1 | Locked | 40.946209 | 0 | 0 |
2 | Locked | 40.366287 | 0 | 0 |
3 | Locked | 40.366287 | 0 | 0 |
4 | Locked | 40.366287 | 0 | 0 |
5 | Locked | 38.983261 | 0 | 0 |
6 | Locked | 40.946209 | 0 | 0 |
7 | Locked | 40.366287 | 0 | 0 |
8 | Locked | 40.946209 | 0 | 0 |
9 | Locked | 40.366287 | 0 | 0 |
10 | Locked | 40.366287 | 0 | 0 |
11 | Locked | 40.366287 | 0 | 0 |
12 | Locked | 40.366287 | 0 | 0 |
13 | Locked | 40.366287 | 0 | 0 |
14 | Locked | 40.366287 | 0 | 0 |
15 | Locked | 38.983261 | 0 | 0 |
16 | Locked | 40.366287 | 0 | 0 |
17 | Locked | 40.366287 | 0 | 0 |
18 | Locked | 40.366287 | 0 | 0 |
19 | Locked | 40.366287 | 0 | 0 |
20 | Locked | 40.366287 | 0 | 0 |
21 | Locked | 40.366287 | 0 | 0 |
22 | Locked | 40.366287 | 0 | 0 |
23 | Locked | 40.946209 | 0 | 0 |
24 | Locked | 40.366287 | 0 | 0 |
26 | Locked | 40.366287 | 0 | 0 |
27 | Locked | 40.366287 | 0 | 0 |
28 | Locked | 40.946209 | 0 | 0 |
29 | Locked | 40.366287 | 0 | 0 |
30 | Locked | 40.946209 | 0 | 0 |
31 | Locked | 40.366287 | 0 | 0 |
33 | 96 | 4K | 1880 | QAM4096 | 759 |
33 | Locked | 42 | 5.8 | 22568616 | 0 |
30-08-2021 16:09 - edited 30-08-2021 16:10
3.0 Upstream channels
1 | 39400000 | 40.5 | 5120 KSym/sec | 64QAM | 6 |
2 | 46200000 | 40.5 | 5120 KSym/sec | 64QAM | 5 |
3 | 32600000 | 41.8 | 5120 KSym/sec | 64QAM | 7 |
4 | 25800000 | 42.3 | 5120 KSym/sec | 16QAM | 8 |
1 | US_TYPE_STDMA | 0 | 0 | 6 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 1 | 0 |
on 30-08-2021 16:10
Fri 27/08/2021 17:44:01 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 27/08/2021 17:44:01 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 27/08/2021 17:44:03 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 27/08/2021 17:44:08 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 27/08/2021 17:44:11 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 27/08/2021 17:44:15 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 27/08/2021 17:44:16 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 27/08/2021 17:44:17 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 27/08/2021 17:44:20 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 27/08/2021 17:44:33 | 6 | CM-STATUS message sent. Event Type Code: 16; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 27/08/2021 17:44:34 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 27/08/2021 17:44:34 | 6 | CM-STATUS message sent. Event Type Code: 2; Chan ID: 4; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 27/08/2021 17:44:37 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 27/08/2021 17:44:37 | 6 | CM-STATUS message sent. Event Type Code: 4; Chan ID: 22; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 27/08/2021 17:44:37 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 27/08/2021 17:44:41 | 6 | CM-STATUS message sent. Event Type Code: 16; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 27/08/2021 17:44:59 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 27/08/2021 17:45:01 | 6 | CM-STATUS message sent. Event Type Code: 16; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 27/08/2021 17:45:02 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 27/08/2021 17:45:07 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 27/08/2021 19:06:49 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 27/08/2021 19:30:23 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 28/08/2021 01:53:30 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 28/08/2021 05:52:55 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 28/08/2021 05:53:00 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 28/08/2021 05:53:06 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 28/08/2021 16:29:08 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 28/08/2021 17:16:37 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 29/08/2021 07:09:50 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 29/08/2021 07:09:54 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 29/08/2021 07:09:55 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 29/08/2021 07:10:01 | 6 | CM-STATUS message sent. Event Type Code: 5; Chan ID: 22; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 29/08/2021 07:10:21 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 29/08/2021 07:10:26 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 29/08/2021 07:10:26 | 6 | CM-STATUS message sent. Event Type Code: 5; Chan ID: 20; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 29/08/2021 07:10:36 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 29/08/2021 07:10:41 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 29/08/2021 07:10:47 | 6 | CM-STATUS message sent. Event Type Code: 23; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 29/08/2021 07:33:31 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 29/08/2021 07:33:32 | 6 | CM-STATUS message sent. Event Type Code: 5; Chan ID: 21; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 29/08/2021 07:34:42 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 29/08/2021 07:34:47 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 29/08/2021 07:34:47 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 29/08/2021 07:34:49 | 6 | CM-STATUS message sent. Event Type Code: 5; Chan ID: 23; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 29/08/2021 07:34:50 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 30-08-2021 19:40
Just had some really bad packetloss as reflected on pingplotter, however not showing as full-on disconnection on BQM
on 30-08-2021 19:46
Hi, you can change your router’s WiFi channel especially if your network tends to overlap with nearby networks. Restart your computer, mobile device or router to help reset the network settings and then try connecting to WiFi again. Check for any pending updates on your computer and install them. Remove and re-add the wireless network.
on 30-08-2021 19:51
Thanks for your reply
All of this is done via Ethernet so wifi signal is not a factor here.
In addition, I've done more than 10 resets on everything in the last 5 days. Theres something else going on here
on 31-08-2021 08:36
Disconnected the ASUS router for the night and it didn't seem to help
Also, full disconnects captured here
https://www.thinkbroadband.com/broadband/monitoring/quality/share/bcdb0c299c0aca558f3de26d72fc6096912287c8-31-08-2021
