  • 10
zinnkio
Message 1 of 5
Constant internet drop outs both WiFi and Ethernet
Up and downstream below. Also started TBB monitoring. Shouldn't be getting these spikes and it's making online gaming a chore.  An engineer has already been and said everything is fine but the problem doesn't arise in the short time he's here. Getting ridiculous now, really need this resolved!
Downstream
12990000008.538256 qam21
24747500008.838256 qam28
34667500008.838256 qam27
44587500008.838256 qam26
54507500008.538256 qam25
63230000008.840256 qam24
73150000008.540256 qam23
83070000008.538256 qam22
92910000008.538256 qam20
102830000008.340256 qam19
112750000008.438256 qam18
12267000000838256 qam17
132590000007.838256 qam16
142510000007.538256 qam15
15243000000738256 qam14
162350000007.138256 qam13
172270000008.338256 qam12
182190000007.938256 qam11
19211000000838256 qam10
202030000007.938256 qam9
211950000007.838256 qam8
221870000007.938256 qam7
231790000007.638256 qam6
241710000007.840256 qam5
1Locked38.9100
2Locked38.9370
3Locked38.9980
4Locked38.9310
5Locked38.9240
6Locked40.940
7Locked40.32260
8Locked38.960
9Locked38.9460
10Locked40.3130
11Locked38.9140
12Locked38.6160
13Locked38.6170
14Locked38.9120
15Locked38.6140
16Locked38.960
17Locked38.980
18Locked38.9120
19Locked38.6110
20Locked38.9210
21Locked38.9200
22Locked38.970
23Locked38.9220
24Locked40.3170
Upstream
13940000043.8512064 qam56
22580000042.5512064 qam58
33260000043512064 qam57
44620000044512064 qam
55
1ATDMA0040
2ATDMA0010
3ATDMA0020
4ATDMA002
0
TBB Latency graph
p.s. posting on behalf of bill payer (father)
  • 10
zinnkio
Message 2 of 5
Re: Constant internet drop outs both WiFi and Ethernet
No mods or admins available to reply?
  • 6.23K
  • 481
  • 1.03K
Hero
Message 3 of 5
Stats look ok. Due to the time of year VM staff are taking longer to get to post, even normally it can be up to a week. Your best bet is to phone customer services and see if there are any area problems.
  • 72
  • 7
andf
Dialled in
Message 4 of 5
There is  similar thread going on in another sub-forum, pasting the same answer here:
".. the connection parameters seems fine, i.e. the same I was seeing before this issue, so I run a continuous ping to the first two IPs visibile when I run a traceroute to bbc.co.uk
Results below:
Reply from 62.252.114.121: bytes=32 time=11ms TTL=62
Reply from 62.252.114.121: bytes=32 time=10ms TTL=62
Reply from 62.252.114.121: bytes=32 time=8ms TTL=62
Request timed out.
Request timed out.
Request timed out.
Reply from 62.252.114.121: bytes=32 time=12ms TTL=62
Reply from 62.252.114.121: bytes=32 time=9ms TTL=62
Request timed out.
Reply from 62.252.114.121: bytes=32 time=18ms TTL=62
Reply from 62.252.114.121: bytes=32 time=7ms TTL=62
Ping statistics for 62.252.114.121:
Packets: Sent = 824, Received = 738, Lost = 86 (10% loss),
Approximate round trip times in milli-seconds:
Minimum = 6ms, Maximum = 94ms, Average = 10ms
Reply from 213.46.174.118: bytes=32 time=11ms TTL=59
Reply from 213.46.174.118: bytes=32 time=10ms TTL=59
Reply from 213.46.174.118: bytes=32 time=15ms TTL=59
Request timed out.
Request timed out.
Request timed out.
Reply from 213.46.174.118: bytes=32 time=17ms TTL=59
Reply from 213.46.174.118: bytes=32 time=14ms TTL=59
Reply from 213.46.174.118: bytes=32 time=9ms TTL=59
Request timed out.
Reply from 213.46.174.118: bytes=32 time=13ms TTL=59
Reply from 213.46.174.118: bytes=32 time=12ms TTL=59
Ping statistics for 213.46.174.118:
Packets: Sent = 957, Received = 904, Lost = 53 (5% loss),
Minimum = 9ms, Maximum = 101ms, Average = 13ms
Assuming that my line is working fine, Virgin core network might have a problem..."
  • 14.59K
  • 432
  • 46
Moderator (Retired) Ralph_R
Moderator (Retired)
Message 5 of 5
Hi zinnkio,
Checking your connection I can see that there have been periods of intermittent FEC on a couple of the upstream channels which may have been the issue.
If the latency issues remain ongoing could you please confirm if this is happening 24/7, or if periodically, the date and time of any drops so we can compare against our network data.
Many thanks
Ralph_R
Forum Moderator
