  • 7
Message 1 of 9
Constant dropouts - wired and wireless
Can someone please run me through what I need to do to diagnose whether the intermittency we have is a problem with the service or downstream of the SH3.  Set up is 100mb; SH3 in modem mode; ASUS RT-AC87U running current version of Merlin; Devolo powerline - both ethernet only hub and AC1200 wifi.  When I ran VM phone support previously the advice was to simply reboot the router and that there were otherwise no problems showing with the service.  The problem has been a constant over the last few years but we've ignored it - being at home all the time now has made it more of an issue.  I'd like to see if it's a problem with the service before I go the next step of getting new hardware.
Wired - at present the laptop I'm on is plugged into LAN 3 (100mb) of the asus and it's dropping out.
Wireless - constant dropouts both before I force set the channels and after.  iphones, laptop and sonos devices regularly lose connection.  I've scanned surrounding channels and set the Asus to use 2.4 and 5 channels that aren't seemingly in use by the competing networks.  Hasn't made an appreciable difference.  Dropouts are worse upstairs but also happening in the same room as the Asus.
Tags (1)
  • 11.46K
  • 889
  • 1.46K
Message 2 of 9
Re: Constant dropouts - wired and wireless
First thing to work out; is the problem a WAN supply problem or an internal LAN problem.
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 11.46K
  • 889
  • 1.46K
Message 3 of 9
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Disable any VPNs that you have running.
Mike Robinson
  • 11.46K
  • 889
  • 1.46K
Message 4 of 9
Can you please
Mike Robinson
  • 7
Message 5 of 9
Router status
thanks Mike, router status
DOWNSTREAM
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
203000000
4.1
37
256 qam
9
2
211000000
4
37
256 qam
10
3
219000000
3.9
37
256 qam
11
4
227000000
3.5
37
256 qam
12
5
235000000
3.4
37
256 qam
13
6
243000000
3.4
37
256 qam
14
7
251000000
3.5
37
256 qam
15
8
259000000
3.5
37
256 qam
16
9
267000000
3.5
37
256 qam
17
10
275000000
3.2
37
256 qam
18
11
283000000
3.5
37
256 qam
19
12
291000000
3.4
37
256 qam
20
13
299000000
3.5
37
256 qam
21
14
307000000
3.5
37
256 qam
22
15
315000000
3.7
37
256 qam
23
16
323000000
3.7
37
256 qam
24
17
331000000
3.7
37
256 qam
25
18
339000000
3.5
37
256 qam
26
19
347000000
3.4
37
256 qam
27
20
355000000
2.9
37
256 qam
28
21
363000000
2.7
37
256 qam
29
22
371000000
2.7
37
256 qam
30
23
379000000
2.9
37
256 qam
31
24
387000000
2.7
37
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
37.3
5
0
2
Locked
37.6
5
0
3
Locked
37.3
6
0
4
Locked
37.3
0
0
5
Locked
37.6
5
0
6
Locked
37.3
4
0
7
Locked
37.3
6
0
8
Locked
37.3
0
0
9
Locked
37.6
4
0
10
Locked
37.6
5
0
11
Locked
37.6
5
0
12
Locked
37.6
4
0
13
Locked
37.3
5
0
14
Locked
37.3
2
0
15
Locked
37.6
5
0
16
Locked
37.6
6
0
17
Locked
37.3
5
0
18
Locked
37.3
0
0
19
Locked
37.6
6
0
20
Locked
37.3
0
0
21
Locked
37.6
5
0
22
Locked
37.6
4
0
23
Locked
37.3
4
0
24
Locked
37.6
0
0
UPSTREAM
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
60300000
49.3
5120
64 qam
1
2
39400000
48.3
5120
64 qam
4
3
53700000
48.8
5120
64 qam
2
4
46200000
48.5
5120
64 qam
3
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
1
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
CONFIGURATION
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057-b.cm
SFID
70750
Max Traffic Rate
117000047
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
70749
Max Traffic Rate
10500047
Max Traffic Burst
16320
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
BestEffort
NETWORK LOG
Time
Priority
Description
10/11/2020 09:44:0
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 09:43:47
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:40
critical
10/11/2020 09:27:55
notice
08/11/2020 16:13:7
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 04:00:43
critical
05/11/2020 04:13:7
Error
01/11/2020 19:43:5
critical
01/11/2020 16:13:6
Error
29/10/2020 22:40:37
critical
29/10/2020 04:13:5
Error
26/10/2020 13:36:10
critical
18/10/2020 16:13:2
Error
15/10/2020 04:46:2
critical
15/10/2020 04:13:1
Error
15/10/2020 02:38:43
critical
11/10/2020 22:33:27
Error
09/10/2020 00:12:2
notice
SW download Successful - Via NMS
09/10/2020 00:10:9
notice
SW Download INIT - Via NMS
07/10/2020 20:52:35
Error
  • 7
Message 6 of 9
BQM
My BQM
  • 7
Message 7 of 9
Speeds
Speed this morning when connected to the SH3 in router mode with no other devices connected averages 75 down and 10 up, across several servers.
Speed this morning through the SH3 in modem mode through the Asus router and to an iphone is today averaging 75 down and 10 up, both in multi and single mode configuration; yesterday it was getting 110 down and 10 up in the mid afternoon.
  • 7
Message 8 of 9
router connection failures
When I was compiling the information this morning and running the speed tests there were frequent drop outs and hangs in both Chrome and Firefox when interacting with the SH3.  The errors occurred when connecting through SH3 + asus router and when connected directly to SH3 in router mode - both using ethernet cable into the device.  This was after rebooting the SH3. When logged to the SH3 in the page would stall and go blank after a button was pushed, and only appear with a force reload.  The SH3 diagnostics tool failed repeatedly, losing connection - about 8 times till I gave up.
The error messages, when connecting through 192.168.0.1 and 192.168.100.1 were
Unable to connect
Firefox can't establish a connection to the server at 192.168.0.1
The site could be temporarily unavailable or too busy.  Try again in a few moments
  • 2.76K
  • 113
  • 154
Message 9 of 9
Hi Yeerung, thanks for messaging us and glad to see that we are on the way to getting this resolved. Please let us know how it goes? Chris
