KHussain1738
  • 13
Message 1 of 25
Constant drop on connection
For the past week I have been having problems with the connection dropping every 20mins or so. Ever since I noticed the problem I have been doing speedtests which have shown the download speed is fine at 200mbps but the upload speed tanks to as low as 0.03mbps when the problems occur. After a couple of seconds the connections returns to normal and the upload speeds return to the normal speeds around 20mbps. This has caused me problems since I am currently working from home and cannot get my work done if the connection keeps dropping. Rang VM and all they told me was hard resets and monitor the situation which I already have been. They have been no help in trying to rectify the issue.
1331000000038256 qam25
22030000002.738256 qam9
32110000002.538256 qam10
42190000002.538256 qam11
52270000001.738256 qam12
6235000000238256 qam13
72430000001.538256 qam14
82510000001.938256 qam15
92590000000.738256 qam16
10267000000138256 qam17
112750000000.538256 qam18
122830000000.738256 qam19
132910000001.438256 qam20
142990000001.738256 qam21
153070000001.538256 qam22
163150000000.538256 qam23
173230000000.438256 qam24
183390000000.438256 qam26
19347000000038256 qam27
20355000000-0.240256 qam28
21363000000-0.538256 qam29
22371000000-0.538256 qam30
23379000000-138256 qam31
24387000000-138256 qam32
1Locked38.690
2Locked38.690
3Locked38.990
4Locked38.960
5Locked38.650
6Locked38.9100
7Locked38.900
8Locked38.990
9Locked38.910
10Locked38.6150
11Locked38.6100
12Locked38.910
13Locked38.6130
14Locked38.970
15Locked38.960
16Locked38.610
17Locked38.910
18Locked38.9130
19Locked38.9110
20Locked40.3130
21Locked38.930
22Locked38.970
23Locked38.900
24Locked38.980
KHussain1738
  • 13
Message 2 of 25
Re: Constant drop on connection
14620006142.3512064 qam1
22360000040.8512032 qam4
33260001240.8512064 qam3
43939997142.3512064 qam2
1ATDMA0010
3ATDMA0000
4ATDMA0000
KHussain1738
  • 13
Message 3 of 25
https://www.thinkbroadband.com/broadband/monitoring/quality/share/122717c3c09d3b701e2340a6917c84fdeaa163aa-12-03-2022
Kath_F
  • 34.71K
  • 1.33K
  • 2.81K
Message 4 of 25
Hi KHussain1738,
Thanks for your post and a big welcome to the Community. It's great having you on board with us.
I'm sorry to hear about the issues you have been having with your broadband. I'm happy to take a look in to things but I've been unable to locate you on our systems using your forum credentials. I will need to confirm some information with you in order for me to proceed with checks.
I have sent you a private message regarding this and will investigate further once I receive your reply. Just click on the little plum envelope at the top right-hand side of the page to access your inbox.
Kath_F
Kath_F
  • 34.71K
  • 1.33K
  • 2.81K
Message 5 of 25
Hi KHussain1738,
Thanks for coming back to via private message to confirm your information.
Looking at things this end, it appears your signal levels are too low. These will need to be adjusted by an engineer. I have booked you in for the next available appointment. To view this please sign in to My Virgin Media here: My VM. Once logged in, scroll down to Orders & appointments then click on View your orders. You can also view this in the My VM app. If you have any issues with accessing your account or unable to see your visit, please do let us know and we’ll pop you another message to pass data protection and then confirm the appointment details.
Just to confirm, there will be no charge for this visit unless:
  • The technician diagnoses the fault as not being caused by our network/equipment
  • The technician discovers that the fault or problem relates to your equipment
  • The technician discovers that the fault or problem relates to any system that we are not responsible for
The technician will confirm during their visit if any of these instances apply, and if so, a £25 charge will be applied to your account.
Please ensure that someone over the age of 18 is at the property for the time the engineer is there. If the appointment is unsuitable or if anyone living at your property has tested positive for Coronavirus, has been asked to self-isolate or has flu-like symptoms then please reschedule the appointment on the same link. If you do miss the appointment for any reason, a £25 missed appointment charge will be applied to your account on the day of the appointment so it is important to reschedule if needed.
Lets us know how the appointment goes.
Take care.
Kath_F
KHussain1738
  • 13
Message 6 of 25
Hi Kath, I cannot see the appointment booked from my account on MyVirginMedia.
Steven_L
  • 11.31K
  • 683
  • 1.15K
Message 7 of 25
Good Morning @KHussain1738 and thanks for coming back to us here.
I'm sorry that we have come back after your appointment went ahead, how did the appointment go, have your issues now been resolved?
Regards,
Steven_L
KHussain1738
  • 13
Message 8 of 25
Hi Steven, the engineer came out and the issue was fixed but once again the problem has started reoccurring after 2 weeks of stability. Not entirely happy with the situation since I am currently working from home and am unable to get stuff done with these intermittent connections.
Alex_RM
  • 7.24K
  • 367
  • 544
Message 9 of 25
Hi KHussain1738,
Sorry to hear you're again experiencing some issues with the connection.
Can you confirm for me if this is an issue over a wired or wireless connection?
Does a pin-hole reset help at all?
Alex_Rm
KHussain1738
  • 13
Message 10 of 25
Hi @Alex_RM, this is an issue over both wired and wifi. The connection just drops and yes, I've already done the pinhole reset etc. Still the same. Rang 150 and went through the steps. Got a text to a link which showed that it is intermittent issues. I will post the link to the current BQM from yesterday to show the massive spikes and constant packet loss. Been ongoing since Monday now and 2nd time this month. Got to say I'm appalled at the service and lack of information given by the people I've had conversations with over the phone.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/9b1aa03114128e3dd86cc80228fdd4a6c5...
