on 05-06-2022 14:28
Every day i get a period of outage where i am unable to use the internet, unable to work from home, unable to do anything.
Sometimes it says a technician is working others it isnt even recognised.
This is absolutely shocking and we plan to leave if this isnt fixed. Theres no point having high speeds if the connection is never working as it should.
Live BQM:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/a906e71057f31fd4f1bd6516834111d845cb450a
on 05-06-2022 14:45
on 05-06-2022 19:13
on 05-06-2022 19:14
Acquired Downstream Channel (Hz) | 299000000 | Locked |
Ranged Upstream Channel (Hz) | 53700000 | Locked |
Provisioning State | Online |
1 | 299000000 | 5.6 | 40 | 256 qam | 21 |
2 | 139000000 | 9.5 | 40 | 256 qam | 1 |
3 | 147000000 | 8.6 | 40 | 256 qam | 2 |
4 | 155000000 | 8.1 | 40 | 256 qam | 3 |
5 | 163000000 | 8 | 40 | 256 qam | 4 |
6 | 171000000 | 7.8 | 40 | 256 qam | 5 |
7 | 179000000 | 7.3 | 40 | 256 qam | 6 |
8 | 187000000 | 7 | 40 | 256 qam | 7 |
9 | 195000000 | 6.9 | 40 | 256 qam | 8 |
10 | 203000000 | 6.5 | 40 | 256 qam | 9 |
11 | 211000000 | 6.5 | 40 | 256 qam | 10 |
12 | 219000000 | 6.5 | 40 | 256 qam | 11 |
13 | 227000000 | 6.4 | 40 | 256 qam | 12 |
14 | 235000000 | 6.5 | 40 | 256 qam | 13 |
15 | 243000000 | 6.4 | 40 | 256 qam | 14 |
16 | 251000000 | 6.1 | 40 | 256 qam | 15 |
17 | 259000000 | 6 | 40 | 256 qam | 16 |
18 | 267000000 | 5.9 | 40 | 256 qam | 17 |
19 | 275000000 | 5.5 | 40 | 256 qam | 18 |
20 | 283000000 | 5.5 | 40 | 256 qam | 19 |
21 | 291000000 | 5.5 | 40 | 256 qam | 20 |
22 | 307000000 | 5.5 | 40 | 256 qam | 22 |
23 | 315000000 | 5.5 | 40 | 256 qam | 23 |
24 | 323000000 | 5.5 | 40 | 256 qam | 24 |
1 | Locked | 40.3 | 5 | 0 |
2 | Locked | 40.9 | 15 | 0 |
3 | Locked | 40.3 | 4 | 0 |
4 | Locked | 40.3 | 5 | 0 |
5 | Locked | 40.3 | 19 | 0 |
6 | Locked | 40.9 | 18 | 0 |
7 | Locked | 40.3 | 5 | 0 |
8 | Locked | 40.9 | 5 | 0 |
9 | Locked | 40.9 | 4 | 0 |
10 | Locked | 40.3 | 5 | 0 |
11 | Locked | 40.3 | 5 | 0 |
12 | Locked | 40.3 | 5 | 0 |
13 | Locked | 40.3 | 5 | 0 |
14 | Locked | 40.9 | 5 | 0 |
15 | Locked | 40.9 | 5 | 0 |
16 | Locked | 40.3 | 5 | 0 |
17 | Locked | 40.9 | 4 | 0 |
18 | Locked | 40.3 | 5 | 0 |
19 | Locked | 40.9 | 5 | 0 |
20 | Locked | 40.9 | 8 | 0 |
21 | Locked | 40.3 | 6 | 0 |
22 | Locked | 40.3 | 4 | 0 |
23 | Locked | 40.9 | 6 | 0 |
24 | Locked | 40.3 | 4 | 0 |
on 05-06-2022 19:14
1 | 53700000 | 42.5 | 5120 | 64 qam | 2 |
2 | 39400041 | 41 | 5120 | 64 qam | 4 |
3 | 46200136 | 42.5 | 5120 | 64 qam | 3 |
4 | 60300000 | 42.5 | 5120 | 64 qam | 1 |
1 | ATDMA | 0 | 0 | 14 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | 873254k;fg87dsfd;kfoA,.iy |
SFID | 16994 |
Max Traffic Rate | 575000000 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 16993 |
Max Traffic Rate | 38520000 |
Max Concatenated Burst | 16320 |
Scheduling Type | BestEffort |
on 05-06-2022 19:15
TimePriorityDescription05/06/2022 17:37:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/06/2022 17:37:34criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/06/2022 17:37:5criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/06/2022 17:36:47ErrorService Add Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/06/2022 17:36:35criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/06/2022 17:36:35criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/06/2022 17:35:47criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/06/2022 17:35:47criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/06/2022 17:35:1criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/06/2022 17:35:1criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/06/2022 17:33:17criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/06/2022 17:33:17criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/06/2022 17:32:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/06/2022 17:32:32criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/06/2022 17:31:47criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/06/2022 17:31:47criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/06/2022 17:31:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/06/2022 17:31:4criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/06/2022 17:29:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/06/2022 17:29:3criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
on 06-06-2022 14:30
