  • 147
  • 8
Blagard
Dialled in
Message 1 of 5
Constant connection issues
As the title and no matter how many times I reboot the Hub it never really gets any better. So some details from the Hub pasted below if it is useful for interpretation.
Downstream ChannelsLock Status Channel ID Frequency Modulation Rx Power SNR Pre RS Errors Post RS Errors
Locked17267000000 HzQAM2568.0 dBmV39.6 dB29190
Locked18275000000 HzQAM2568.0 dBmV39.5 dB27700
Locked19283000000 HzQAM2567.6 dBmV39.1 dB27920
Locked20291000000 HzQAM2567.2 dBmV38.7 dB28130
Locked21299000000 HzQAM2568.8 dBmV38.6 dB366310
Locked22307000000 HzQAM2569.0 dBmV38.2 dB35060
Locked23315000000 HzQAM2568.9 dBmV37.9 dB34810
Locked24323000000 HzQAM2568.3 dBmV37.7 dB356912
Upstream ChannelsLock Status Channel ID Frequency Modulation Tx Power Mode Channel Bandwidth Symbol Rate
Locked3625800000 HzATDMA46.3 dBmV64QAM640000030720 Kbits/sec
Locked3346200000 HzATDMA47.3 dBmV64QAM640000030720 Kbits/sec
Locked3439400000 HzATDMA46.8 dBmV64QAM640000030720 Kbits/sec
Locked3532600000 HzATDMA46.8 dBmV64QAM640000030720 Kbits/sec
  • 18.94K
  • 1.65K
  • 4.14K
Message 2 of 5
Re: Constant connection issues
your upstream power levels are fine.. but your downstream is all not looking so good.. first would be checking all coax (white cable) are finger tight.. since looking for power levels on downstream close to 0dbmv as possible.. but anything around 0 to 6dbmv is ok depending on some other factors..
if the power levels are around the same, this more than likely would require a tech visit can wait around 2-5+ days for the forum staff to reply, or if need quicker can call faults via 150 / 0345 454 1111
  • 11.49K
  • 502
  • 748
Forum Team (Retired) Josh_RW
Message 3 of 5
Hi Blagard,
Thanks for posting!
I'm sorry to hear you're having trouble with your connection.
I've run diagnostics on your equipment and can confirm paultechy's assessment is correct. We'll need to send a technician to adjust your downstream levels.
I've sent you a private message (purple envelope at the top right of your screen) so I can arrange an appointment.
Speak soon
Josh
  • 147
  • 8
Blagard
Dialled in
Message 4 of 5
I have just resited my Hub without making any changes to the connections. The new location is more central and fewer bends on the cable, however the connection data is no better. So I assume I need to book a visit. Data from the router is below.
Locked1139000000 HzQAM2566.7 dBmV40.8 dB7390
Locked2147000000 HzQAM2567.5 dBmV41.4 dB7150
Locked3155000000 HzQAM2567.5 dBmV40.9 dB6880
Locked4163000000 HzQAM2567.2 dBmV40.8 dB6760
Locked5171000000 HzQAM25610.3 dBmV40.8 dB16430
Locked6179000000 HzQAM25610.4 dBmV40.8 dB16090
Locked7187000000 HzQAM25610.0 dBmV40.8 dB16010
Locked8195000000 HzQAM2569.3 dBmV40.3 dB15900
Locked3532600000 HzATDMA45.0 dBmV64QAM640000030720 Kbits/sec
Locked3346200000 HzATDMA45.0 dBmV64QAM640000030720 Kbits/sec
Locked3439400000 HzATDMA44.8 dBmV64QAM640000030720 Kbits/sec
Locked3625800000 HzATDMA44.5 dBmV64QAM640000030720 Kbits/sec
  • 15.2K
  • 653
  • 32
Moderator (Retired) John_G
Moderator (Retired)
Message 5 of 5
Hi Blagard,
The downstream power levels you've posted are ranged too far and that's likely to cause problems. Let's get a technician arranged. I've just sent you a private message to get this process started.
