on 06-06-2021 13:03
Since Wednesday there have been contestant dropouts, usually in the evening but have also been disconnecting all morning (06/06/2021) also.
Not sure what to post, but below are some stats.
Acquired Downstream Channel (Hz) | 139000000 | Locked |
Ranged Upstream Channel (Hz) | 60300000 | Locked |
Provisioning State | Online |
1 | 139000000 | 12 | 40 | 256 qam | 1 |
2 | 147000000 | 12.1 | 40 | 256 qam | 2 |
3 | 155000000 | 12 | 40 | 256 qam | 3 |
4 | 163000000 | 12 | 40 | 256 qam | 4 |
5 | 171000000 | 11.5 | 40 | 256 qam | 5 |
6 | 179000000 | 11.5 | 40 | 256 qam | 6 |
7 | 187000000 | 11.5 | 40 | 256 qam | 7 |
8 | 195000000 | 11.6 | 40 | 256 qam | 8 |
9 | 203000000 | 11.5 | 40 | 256 qam | 9 |
10 | 211000000 | 11.4 | 40 | 256 qam | 10 |
11 | 219000000 | 11.5 | 40 | 256 qam | 11 |
12 | 227000000 | 11.3 | 40 | 256 qam | 12 |
13 | 235000000 | 11.5 | 40 | 256 qam | 13 |
14 | 243000000 | 11 | 40 | 256 qam | 14 |
15 | 251000000 | 11.1 | 40 | 256 qam | 15 |
16 | 259000000 | 9.9 | 40 | 256 qam | 16 |
17 | 267000000 | 10 | 40 | 256 qam | 17 |
18 | 275000000 | 10.4 | 40 | 256 qam | 18 |
19 | 283000000 | 11.5 | 40 | 256 qam | 19 |
20 | 291000000 | 11.4 | 40 | 256 qam | 20 |
21 | 299000000 | 12.1 | 40 | 256 qam | 21 |
22 | 307000000 | 12 | 40 | 256 qam | 22 |
23 | 315000000 | 12.5 | 40 | 256 qam | 23 |
24 | 323000000 | 12.3 | 38 | 256 qam | 24 |
1 | Locked | 40.3 | 4562 | 9662 |
2 | Locked | 40.3 | 4549 | 11779 |
3 | Locked | 40.3 | 4263 | 10632 |
4 | Locked | 40.3 | 3917 | 8978 |
5 | Locked | 40.9 | 3799 | 10668 |
6 | Locked | 40.3 | 3870 | 9566 |
7 | Locked | 40.9 | 3693 | 5806 |
8 | Locked | 40.3 | 2998 | 7394 |
9 | Locked | 40.9 | 2969 | 10807 |
10 | Locked | 40.3 | 3150 | 11589 |
11 | Locked | 40.9 | 2991 | 9902 |
12 | Locked | 40.3 | 2910 | 6300 |
13 | Locked | 40.3 | 2923 | 6026 |
14 | Locked | 40.9 | 2844 | 5820 |
15 | Locked | 40.3 | 2861 | 4720 |
16 | Locked | 40.3 | 2555 | 3918 |
17 | Locked | 40.3 | 2464 | 4605 |
18 | Locked | 40.3 | 2448 | 5025 |
19 | Locked | 40.9 | 2480 | 4002 |
20 | Locked | 40.3 | 2256 | 3732 |
21 | Locked | 40.9 | 2247 | 3130 |
22 | Locked | 40.3 | 2063 | 4328 |
23 | Locked | 40.3 | 2198 | 4437 |
24 | Locked | 38.9 | 2191 | 3802 |
1 | 60300000 | 45.5 | 5120 | 64 qam | 1 |
2 | 46200000 | 45.3 | 5120 | 64 qam | 3 |
3 | 39400000 | 45.5 | 5120 | 64 qam | 4 |
4 | 53700000 | 45.5 | 5120 | 64 qam | 2 |
1 | ATDMA | 0 | 0 | 1 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
Service status, number and website both say everything is ok in my area. Any ideas?
06-06-2021 13:17 - edited 06-06-2021 13:18
Edit: Upstream Downstream power looks too high. I'll flag for the forum staff to advise - could be an area fault, or unique to your connection. Subject to any checks they need to make, if it's unique to you then they can if needed book a technician visit.
on 06-06-2021 14:56
Hi @Wymer
I'm going to private message you to take a look into this further, please keep an eye on your inbox.
on 02-07-2021 13:30
After the Engineer came, we had good service with no drops out for around 2 weeks. Then since 22nd June the issues came back slowly.
The first week of the issues was sorted by resetting the hub every 3-4 days, but since 29th June this is no longer the case, and there seems to no effect at all when we reboot the hub.
Currently, for our work, we are just using our mobile data as a hotspot, as the broadband connection is not reliable. Is there anything else we can do at all?
Looking through the forums it looks like this is *very* common, and the last time we had this issue a few years ago, we were supplied a new hub which solved the issue, and exactly the same a few years prior to that. Do you think that would help at all?
Thank you
on 02-07-2021 13:46
Hi @Wymer,
Thank you so much for getting back to us in regards to your connection issue.
I can see that there are some upstream power level issues showing on our system. In order to have this looked into further, I will need to book a technician appointment.
Please keep a look out for a purple envelope at the top corner of your forum page. I will be in touch soon to confirm a few details.
Thanks! 🙂
on 02-07-2021 15:42
Hi @Wymer,
Thank you for confirming your details with me over Private Message.
I was able to book a technician appointment for you, for the engineer to look over any ongoing issues you may be experiencing.
I shared your appointment details with you over Private Message. You can also manage your appointment on your online account if needed.
Please keep us updated and let us know how your appointment goes please! 🙂
on 06-07-2021 12:47
Hi 😀 the engineer has came out about an hour ago and fitted a new wire. The dropouts have now started again.
I get that you are not replacing hubs due the the chip shortage but that’s the only thing left to do now as a wire and a limiter in the back of the old hub are not working.
It's been almost a month now of reporting the issues with the connection, so it's getting to the point that if the issues are not fixed soon, we will have to look at alternative suppliers as we are not able to use the internet.
on 06-07-2021 12:57
Hi there @Wymer
Thank you so much for your update and I am so sorry to hear the drops have happened so soon after the visit!
Can I ask if the engineer gave any advise as to what do to next should this fix fail to resolve the issue? Are you able to call us on 0345 454 1111 to speak to an adviser who may be able to arrange for the engineer to pop back as the issue doesn't appear to be resolved?
on 06-07-2021 13:19
Post up your hub stats again - let's see what the engineer has done!
on 11-08-2021 21:43
This issue has started happening again from yesterday. With constant dropouts in the connection again.
No faults have been reported in the area, any ideas? it's strange that twice now an engineer has came out, and then a few weeks later the problem happens again.
Thank you
