on 29-09-2021 09:23
Hi, I’m looking for some help please.
The last 16+ weeks my router has had a constant red light on it and there’s been WiFi connection issues ever since.
Following the self help section which states overheating I’ve pulled the router out a bit to no success. I’ve since done 3 pin hole resets with the router to that also having no success. I’ve now been in contact with tech support with that also having no success with them stating they are providing the service with the internet working via Ethernet cable even though this error light is constant and the wifi is inconsistent.
How do I go about trying to fix this or even getting a new router?
Picture added today with the light showing still.
Many thanks
on 29-09-2021 11:36
Hi @MaxF88
Welcome to our Community Help Forum 🙂
Thank you for making your first post regarding the red light that is showing on your Hub. I am concerned that your Hub is overheating and I would like to book a techician appointment to get this resolved.
I shall send you a private message now to obtain the details required and confirm your address. Please look out for the purple envelope in the top right corner and get back to me when you can 🙂
Best wishes,
Serena
