on 18-12-2021 16:16
I'm getting fairly constant packet loss and latency spikes on my 1GB connection and have been for some weeks now. It is affecting both gaming and VOIP comms on things like Zoom and Discord. It is getting very frustrating because I both work from home and do a lot of online gaming, both of which are impacted.
Is there anything that can be done about this? Is it contention? A noisy line?
Any help would be appreciated.
Supporting data below.
Think Broadband graph:
on 18-12-2021 16:18
Hub data:
Hub Downstream:
3.0 Downstream channels
26 339000000 6.300003 40.366287 QAM256 26
1 139000000 4.800003 40.366287 QAM256 1
2 147000000 5.000000 40.366287 QAM256 2
3 155000000 5.300003 40.946209 QAM256 3
4 163000000 5.099998 40.366287 QAM256 4
5 171000000 4.300003 40.366287 QAM256 5
6 179000000 4.800003 40.946209 QAM256 6
7 187000000 5.400002 40.366287 QAM256 7
8 195000000 5.699997 40.946209 QAM256 8
9 203000000 5.800003 40.946209 QAM256 9
10 211000000 5.599998 40.946209 QAM256 10
11 219000000 3.700001 40.366287 QAM256 11
12 227000000 5.900002 40.946209 QAM256 12
13 235000000 6.300003 40.366287 QAM256 13
14 243000000 6.099998 40.946209 QAM256 14
15 251000000 5.900002 40.946209 QAM256 15
16 259000000 6.300003 40.946209 QAM256 16
17 267000000 6.900002 40.946209 QAM256 17
18 275000000 7.500000 40.946209 QAM256 18
19 283000000 7.199997 40.946209 QAM256 19
20 291000000 6.699997 40.946209 QAM256 20
21 299000000 5.900002 40.946209 QAM256 21
22 307000000 6.199997 40.946209 QAM256 22
23 315000000 6.599998 40.366287 QAM256 23
24 323000000 6.599998 40.366287 QAM256 24
25 331000000 6.300003 40.366287 QAM256 25
27 347000000 5.800003 40.366287 QAM256 27
28 355000000 5.199997 40.366287 QAM256 28
29 363000000 5.400002 40.946209 QAM256 29
30 371000000 5.500000 40.946209 QAM256 30
31 379000000 5.300003 40.366287 QAM256 31
26 Locked 40.366287 1 0
1 Locked 40.366287 0 0
2 Locked 40.366287 0 0
3 Locked 40.946209 0 0
4 Locked 40.366287 0 0
5 Locked 40.366287 0 0
6 Locked 40.946209 0 0
7 Locked 40.366287 0 0
8 Locked 40.946209 0 0
9 Locked 40.946209 0 0
10 Locked 40.946209 0 0
11 Locked 40.366287 0 0
12 Locked 40.946209 0 0
13 Locked 40.366287 0 0
14 Locked 40.946209 0 0
15 Locked 40.946209 0 0
16 Locked 40.946209 0 0
17 Locked 40.946209 0 0
18 Locked 40.946209 1 0
19 Locked 40.946209 0 0
20 Locked 40.946209 0 0
21 Locked 40.946209 1 0
22 Locked 40.946209 0 0
23 Locked 40.366287 0 0
24 Locked 40.366287 0 0
25 Locked 40.366287 1 0
27 Locked 40.366287 1 0
28 Locked 40.366287 0 0
29 Locked 40.946209 1 0
30 Locked 40.946209 1 0
31 Locked 40.366287 2 0
3.1 Downstream channels
159 96 4K 1880 QAM2048 424
159 Locked 44 8.8 426936403 5078
Hub Upstream:
3.0 Upstream channels
1 60300000 43.770599 5120 KSym/sec 64QAM 1
2 39400000 43.270599 5120 KSym/sec 64QAM 4
3 46200000 42.770599 5120 KSym/sec 64QAM 3
4 53700000 43.770599 5120 KSym/sec 64QAM 2
1 US_TYPE_STDMA 0 0 11 0
2 US_TYPE_STDMA 0 0 3 0
3 US_TYPE_STDMA 0 0 11 0
4 US_TYPE_STDMA 0 0 16 0
18-12-2021 16:19 - edited 18-12-2021 16:21
No, not contention or network congestion, "just" noise-related packet loss which is usually an easy fix (and may even be an area fault that's already under investigation for a fix).
EDIT: You've posted the hub data as I was writing. Main thing I observe is a very high upstream timeout count, and too many uncorrectable errors on the downstream D3.1 channel. I'll flag that for our friendly forum staff to take a look and advise.
on 19-12-2021 11:17
Thanks for your post and for reaching out to the Community Forums, teadazed,
I've sent you a private message to confirm your account details so we can take a closer look at your connection.
Cheers,
Corey C
on 19-12-2021 13:45
I've responded, thanks.
