on 16-09-2022 13:03
I'm changing cables I've just changed over too RG6u. I'm unable to get connection. What is the reason.
on 16-09-2022 14:24
on 16-09-2022 16:40
No there not from vm.
on 16-09-2022 16:43
on 16-09-2022 16:48
In which case, you have either used the wrong cable or not fitted the plugs/connectors properly. There is also a non zero chance that you have introduced noise into the system and have compromised your neighbour’s connection - and no it’s not entirely an urban myth, it can and does happen.
You are probably going to have to call VM and book a technician visit, as this is a sort of self-inflicted issue, they’ll charge you £25.
on 16-09-2022 16:48
