Message 1 of 9
Connection keeps dropping
Can't seem to keep internet connection for more than a few minutes (2nd go at this).  Loses connection and comes back with either 2 power cycles or maybe just comes back about 40 minutes later.  Expired my 6 equipment test for the day (all failed).  Phone help isn't there.
  • 24.56K
  • 1.41K
  • 3.12K
Message 2 of 9
Re: Connection keeps dropping
Wired or wireless connections?
Message 3 of 9
Wired and wireless all go at the same time
  • 24.56K
  • 1.41K
  • 3.12K
Message 4 of 9
Post the Network, Upstream and Downstream logs from the hubs admin pages
Message 5 of 9
26/10/2020 13:52:34
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 11:43:34
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 11:24:37
notice
SW download Successful - Via Config file
26/10/2020 11:22:30
notice
SW Download INIT - Via Config file
26/10/2020 10:58:32
critical
26/10/2020 10:58:2
critical
REG RSP not received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 10:58:2
Error
T6 Timeout and retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 10:58:2
critical
Registration RSP rejected unspecified reason;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 10:58:2
critical
Registration RSP rejected message syntax error;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 10:52:18
critical
26/10/2020 10:51:27
critical
26/10/2020 10:49:40
critical
26/10/2020 10:48:50
critical
26/10/2020 10:48:21
critical
26/10/2020 10:47:32
critical
26/10/2020 10:46:57
critical
26/10/2020 09:39:40
critical
26/10/2020 09:34:44
critical
26/10/2020 07:41:1
critical
26/10/2020 07:35:30
critical
  • 17.34K
  • 1.82K
  • 3.02K
Message 6 of 9
Logs not looking good. Post up all the data from the downstream and upstream pages as well
Also, in the meantime, if you haven’t already, set up a free “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, etc - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” (as per instructions on the TB website) when you have the first 24h period.
Message 7 of 9
The tables do not transfer very sensibly.  I think it is misinterpreted HTML, but I'll have a think of how to get them in.  There is nothing showing in the upstream list.
The downstream reports Pre RS errors on most channels (23/24).  Most single figures, but includes 14, 15, 15, 16.
I'll have a look at getting the monitor.
  • 17.34K
  • 1.82K
  • 3.02K
Message 8 of 9
"The tables do not transfer very sensibly."
Yes they do, there are dozens posted up every day on these fora, just scan through a few threads you will see them.
Copy and paste as formatted text if you get the HTML error when you press send - then just press send again and they will go.
  • 24.56K
  • 1.41K
  • 3.12K
Message 9 of 9
Copy and paste the tables as requested. Ignore any HTML errors when posting and just click post again.
