on 09-09-2022 19:56
I seem to be having an issue with the connection dropping out every night between 7 and 8. It's very brief and comes straight back, but why would this happen and how can it be fixed?
I've done the online tests and it says nothing is wrong. Restarted AND reset the router but neither has helped.
We've had an engineer out earlier this week as well as we were previously informed the router had some range issues. Our area has had several problems over recent months so is this part of that? Or is it these new hubs since it has been randomly dropping connection since we got it?
This week has at least been consistent - it's never exactly the same time but always between 7 and 8 each night.
on 09-09-2022 20:33
on 09-09-2022 23:56
I mostly notice it on a wired connection since that's what I use most. Sometimes it has also affected wi-fi, but it's possible by the time I access a wi-fi device it is already back up and running.
The obvious giveaway is if I'm running a download (or many) it will cut out, so it seems like a disconnect or severe packet loss at some point between those hours but I can't trace a cause. I'll run the monitor and see what it says.
on 10-09-2022 15:10
on 10-09-2022 19:59
on 10-09-2022 21:13
on 11-09-2022 20:06
on 12-09-2022 14:39
Hi @lemming3k
Thanks for posting on our community forum and sorry to hear about the issues with your connection.
I am going to drop you a private message now to collect some more information, please keep an eye on your inbox for a message from myself so we can get this sorted for you.
