31-10-2022 15:59 - edited 31-10-2022 16:07
Hi there, I need some help please as my fibre 100 broadband connection is dropping out almost once an hour.
The service was working fine for around 6 months and all of a sudden started dropping out all the time about a month ago. - nothing has changed my end. the drop outs last about 30 seconds and then it starts working again. Speed test is fine otherwise.
Edit - drop outs occur on all devices WI-Fi and ethernet cable connected devices
I've already called up the helpline a few times and tried all the resets and pinhole resets. I was supposed to get a call back but its not happened. The drop outs are kicking me out of my work connection which I really need to be stable and kicking me out of any games I am playing which is very frustrating.
Here is the BQM which I started last night. You can see ive experienced 5-6 dorp outs before lunchtime today even,
I will copy my router stats below as others have done. the power looks ok but I have no idea what any other other stuff should be reading.
Do I need an angineer visit?? - really need this resolving asap.
Rob
1 | 139000000 | -1.9 | 38 | 256 qam | 1 |
2 | 147000000 | -0.9 | 38 | 256 qam | 2 |
3 | 155000000 | -0.7 | 38 | 256 qam | 3 |
4 | 163000000 | -0.5 | 38 | 256 qam | 4 |
5 | 171000000 | 0 | 38 | 256 qam | 5 |
6 | 179000000 | 0.2 | 38 | 256 qam | 6 |
7 | 187000000 | 1.2 | 38 | 256 qam | 7 |
8 | 195000000 | 1.2 | 40 | 256 qam | 8 |
9 | 203000000 | 0.5 | 38 | 256 qam | 9 |
10 | 211000000 | 1.5 | 38 | 256 qam | 10 |
11 | 219000000 | 2.4 | 40 | 256 qam | 11 |
12 | 227000000 | 1.9 | 38 | 256 qam | 12 |
13 | 235000000 | 0.2 | 38 | 256 qam | 13 |
14 | 243000000 | 0.7 | 38 | 256 qam | 14 |
15 | 251000000 | 0.7 | 38 | 256 qam | 15 |
16 | 259000000 | 0 | 40 | 256 qam | 16 |
17 | 267000000 | 0.2 | 38 | 256 qam | 17 |
18 | 275000000 | 0.2 | 40 | 256 qam | 18 |
19 | 283000000 | 1.2 | 40 | 256 qam | 19 |
20 | 291000000 | 0.4 | 38 | 256 qam | 20 |
21 | 299000000 | 0 | 38 | 256 qam | 21 |
22 | 307000000 | 0.2 | 40 | 256 qam | 22 |
23 | 315000000 | 0.9 | 40 | 256 qam | 23 |
24 | 323000000 | 0.2 | 38 | 256 qam | 24 |
1 | Locked | 38.6 | 4502 | 142935 |
2 | Locked | 38.9 | 2183 | 5891 |
3 | Locked | 38.6 | 971 | 5537 |
4 | Locked | 38.9 | 1424 | 5142 |
5 | Locked | 38.6 | 1228 | 4944 |
6 | Locked | 38.9 | 542 | 4922 |
7 | Locked | 38.9 | 466 | 4780 |
8 | Locked | 40.3 | 438 | 4880 |
9 | Locked | 38.9 | 608 | 5483 |
10 | Locked | 38.6 | 570 | 4956 |
11 | Locked | 40.3 | 469 | 5009 |
12 | Locked | 38.6 | 578 | 5000 |
13 | Locked | 38.9 | 734 | 4566 |
14 | Locked | 38.9 | 759 | 4867 |
15 | Locked | 38.9 | 742 | 5239 |
16 | Locked | 40.3 | 861 | 5322 |
17 | Locked | 38.9 | 865 | 5546 |
18 | Locked | 40.3 | 952 | 3928 |
19 | Locked | 40.3 | 853 | 4346 |
20 | Locked | 38.9 | 1111 | 4943 |
21 | Locked | 38.6 | 1301 | 6166 |
22 | Locked | 40.3 | 1375 | 4932 |
23 | Locked | 40.3 | 1452 | 4471 |
24 | Locked | 38.9 | 1817 | 4036 |
1 | 49600000 | 45 | 5120 | 64 qam | 1 |
2 | 43100090 | 46.3 | 5120 | 64 qam | 2 |
3 | 30100000 | 46.8 | 5120 | 64 qam | 4 |
4 | 23600000 | 43.5 | 5120 | 64 qam | 5 |
5 | 36600375 | 46.5 | 5120 | 64 qam | 3 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 1 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
5 | ATDMA | 0 | 0 | 0 | 0 |
on 31-10-2022 15:59
on 31-10-2022 16:11
31-10-2022 16:13 - edited 31-10-2022 16:18
Thanks - I am on Hub 3.0. It was working fine for months and all of a sudden this.
I will add that the hub lights stay the same during a drop out - just the regular whiteish light on display.
30 seconds to 1 minuite later its back to normal for a bit before doing it again
on 02-11-2022 11:45
Do I need to bump this ? Does anyone know if there is a timescale for the VM team to respond on here?
apologies if it’s in some sort of queue system but I’ve still not heard back from the contact centre and the dropouts are plaguing me.
on 04-11-2022 12:16
Hi robjonaldo,
Thank you for your post and welcome to the community.
I'm very sorry to hear about the issue you've been having with your broadband service.
I have taken a look on our side and it looks as though you have been able to speak with the team regarding this.
Has this now been resolved for you?
^Martin
on 04-11-2022 12:37
Hi Martin.
I finally got a tech visit booked in yesterday.
They are coming on Tuesday afternoon so fingers crossed they can do something.
Rob
on 06-11-2022 15:14
Hi robjonaldo,
Thank you for reaching back out to us, glad to hear you have been able to arrange a technician, To view or amend the appointment sign in to your Online Account, once you log in scroll down to Orders & appointments then click on View your orders.
Just to confirm, there will be no charge for this visit unless:
The technician diagnoses the faults as not being caused by our network/equipment
The technician discovers that the fault or problem relates to your equipment
The technician discovers that the fault or problem relates to any system that we are not responsible for
The technician will confirm during their visit if any of these instances apply, and if so, a £25 charge will be applied to your account.
Please ensure that someone over the age of 18 is at the property for the time the engineer is there. If the appointment is unsuitable or if anyone living at your property has tested positive for Coronavirus, has been asked to self-isolate or has flu-like symptoms then please reschedule the appointment on the same link. If you do miss the appointment for any reason, a £25 missed appointment charge will be applied to your account on the day of the appointment so it is important to reschedule if needed.
Lets us know how the appointment goes.
Paul.
09-11-2022 11:47 - edited 09-11-2022 11:52
Hi there.
The technician visited yesterday on 08/10/2022
He replaced the cables from the wall to the rotuer inside the house and fitted a new isolator. He replaced two corroded connections one outside the house where the incoming cable joins and one in the cabinet. He said the rest of the cabinet looked fine (not anywhere near overloaded) and the noise appeared to have dissapeared.
Last night the connection seemed better however today I have experienced three drop outs this morning again.
Here is my BQM for today.
3pm yesterday - technician working
You can see the connection has improved compared to what is was before the technician came at 2pm.
Still appears to be noise on the line more than normal and today two drop outs around 8am and a third 11:30 am.
A friend of mine lives two streets away on the same VM package (albeit probably different cabinet etc) and his BQM is much much flatter and quieter than mine.
I was really hoping this was fixed but it seems something is still wrong here. Please can you advise of the next steps as this is affecting my work, tv streaming and gaming time.
Rob
on 09-11-2022 12:56
