swift_sport_60
Message 1 of 7
Connection dropouts
Hi guys,
I have recently started having some issues with my broadband, this is the log when i lose connection.
Network Log First Time     Last Time     Priority     Error Number     Description
04/11/2018 19:49:26 GMT    04/11/2018 19:49:26 GMT    Critical (3)    84000500    SYNC Timing Synchronization failure - Loss of Sync
04/11/2018 19:49:24 GMT    04/11/2018 19:49:24 GMT    Critical (3)    84000500    SYNC Timing Synchronization failure - Loss of Sync
04/11/2018 19:48:21 GMT    04/11/2018 19:48:21 GMT    Warning (5)    84020200    Lost MDD Timeout
04/11/2018 19:48:19 GMT    04/11/2018 19:48:19 GMT    Warning (5)    84020200    Lost MDD Timeout
04/11/2018 19:48:17 GMT    04/11/2018 19:48:17 GMT    Warning (5)    84020200    Lost MDD Timeout
04/11/2018 19:48:16 GMT    04/11/2018 19:48:16 GMT    Critical (3)    84000500    SYNC Timing Synchronization failure - Loss of Sync
04/11/2018 19:48:15 GMT    04/11/2018 19:48:15 GMT    Critical (3)    84000500    SYNC Timing Synchronization failure - Loss of Sync
04/11/2018 19:48:14 GMT    04/11/2018 19:48:14 GMT    Critical (3)    84000500    SYNC Timing Synchronization failure - Loss of Sync
04/11/2018 19:48:13 GMT    04/11/2018 19:48:13 GMT    Critical (3)    84000500    SYNC Timing Synchronization failure - Loss of Sync
04/11/2018 19:48:11 GMT    04/11/2018 19:48:11 GMT    Critical (3)    84000500    SYNC Timing Synchronization failure - Loss of Sync
04/11/2018 19:48:10 GMT    04/11/2018 19:48:10 GMT    Critical (3)    84000500    SYNC Timing Synchronization failure - Loss of Sync
04/11/2018 19:48:09 GMT    04/11/2018 19:48:09 GMT    Critical (3)    84000500    SYNC Timing Synchronization failure - Loss of Sync
04/11/2018 19:48:08 GMT    04/11/2018 19:48:08 GMT    Critical (3)    84000500    SYNC Timing Synchronization failure - Loss of Sync
Downstream       DS-1     DS-2     DS-3     DS-4     DS-5     DS-6     DS-7     DS-8
Frequency (Hz)     202750000     210750000     218750000     226750000     234750000     242750000     250750000     258750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)     Locked     Locked     Locked     Locked     Locked     Locked     Locked     Locked
Channel ID     9     10     11     12     13     14     15     16
Modulation     256QAM     256QAM     256QAM     256QAM     256QAM     256QAM     256QAM     256QAM
Symbol Rate (Msym/sec)     6.952000     6.952000     6.952000     6.952000     6.952000     6.952000     6.952000     6.952000
Interleave Depth     I=12
J=17     I=12
J=17     I=12
J=17     I=12
J=17     I=12
J=17     I=12
J=17     I=12
J=17     I=12
J=17
Power Level (dBmV)     -2.25     -1.87     -1.80     -1.80     -2.04     -2.04     -2.06     -2.10
RxMER (dB)     25.47     28.46     26.99     27.41     33.16     34.63     35.42     32.50
Pre RS Errors
6717927     11416462     32480966     99407682     3990901     1108812     379477     1347929
Post RS Errors
373580     1658429     2329374     2268633     5210     4797     2640     1459
Upstream       US-1     US-2     US-3     US-4
Channel Type     2.0     2.0     2.0     2.0
Channel ID     4     2     3     1
Frequency (Hz)     25800000     39400000     32600000     46200000
Ranging Status     Success     Success     Success     Success
Modulation     16QAM     16QAM     16QAM     16QAM
Symbol Rate (Sym/sec)     5120000     5120000     5120000     5120000
Mini-Slot Size     2     2     2     2
Power Level (dBmV)     48.50     50.00     49.25     50.25
T1 Timeouts     0     0     0     0
T2 Timeouts     0     0     0     0
T3 Timeouts     1     0     0     0
T4 Timeouts     0     0     0     0
And this is after a reboot
J=17     I=12
J=17     I=12
J=17     I=12
J=17     I=12
J=17     I=12
J=17     I=12
J=17     I=12
J=17
Power Level (dBmV)     -1.18     -0.83     -0.82     -0.85     -0.97     -1.00     -1.00     -0.96
RxMER (dB)     37.36     37.94     37.94     37.94     37.64     37.64     39.40     37.64
Pre RS Errors
286     278     291     280     306     284     305     298
Post RS Errors
279     276     290     280     294     282     296     286
  • 19.23K
  • 1.68K
  • 4.22K
Message 2 of 7
Re: Connection dropouts
the downstream SnR is showing a massive issue.. would make sure all white (coax) cable are finger tight, would be close to a week for the forum staff to check things over. with high chance will require a tech visit, if need quicker would need to call faults via 150 / 0345 454 1111
If someone's helped you out say thanks by clicking on the thumbs up on kudos. If someone's solved your problem, why not mark their message as an Accepted Solution, but only do this once issue has been resolved.
  • 86
  • 14
gordan
Up to speed
Message 3 of 7
It's interesting that a reboot boosted your power levels by 1 dBmV. Ideally it should be between 0 and 4 dBmV.
If you have an attenuator on the back of your modem, try removing it (and if so, how many dB is it?). If you don't have an attenuator, and there is nothing obviously wrong with the cabling, call VM and get them to send an engineer to connect you to a higher gain tap.
  • 5.3K
  • 105
Moderator (Retired) Ty_S
Moderator (Retired)
Message 4 of 7
Hi swift_sport_60
I’m really sorry to hear of these connection issues you've had.
I'm unable to locate your account so I’ve sent you a private message (purple envelope, top right corner) for some additional information to help me look into this further for you.
Kind regards,
  • 5.3K
  • 105
Moderator (Retired)
Message 5 of 7
Hi swift_sport_60
Thanks for responding to my message. I've been able to run some checks on your connection and everything looks great at the moment. Hub power levels look fine and are SNR is good. Are you still experiencing these disconnections?
If so, are you connected wired or wireless? Could you post a copy of the hubs network log?
Speak soon
swift_sport_60
Message 6 of 7
Hi, the connection has been fine recently.
I only use a wired connection where i can because all of my wireless deviced can sometime take ages to connect to the superhub.
Here is the network log
First TimeLast TimePriorityError NumberDescription
10/11/2018 22:55:53 GMT10/11/2018 22:55:53 GMTError (4)68010400DHCP REBIND WARNING - Field invalid in response
10/11/2018 22:54:55 GMT10/11/2018 22:54:55 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
10/11/2018 22:54:00 GMT10/11/2018 22:54:00 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
10/11/2018 22:52:08 GMT10/11/2018 22:52:08 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
10/11/2018 22:48:27 GMT10/11/2018 22:48:27 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
10/11/2018 22:41:05 GMT10/11/2018 22:41:05 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
10/11/2018 22:26:20 GMT10/11/2018 22:26:20 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
10/11/2018 21:56:49 GMT10/11/2018 21:56:49 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
10/11/2018 21:25:54 GMT10/11/2018 21:25:54 GMTWarning (5)66050310Auth Success - Web login successful.
10/11/2018 20:57:46 GMT10/11/2018 20:57:46 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
10/11/2018 18:59:42 GMT10/11/2018 18:59:42 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
10/11/2018 15:03:34 GMT10/11/2018 15:03:34 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
10/11/2018 07:11:17 GMT10/11/2018 07:11:17 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
09/11/2018 15:26:44 GMT09/11/2018 15:26:44 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
05/11/2018 04:09:15 GMT05/11/2018 04:09:15 GMTCritical (3)84000500SYNC Timing Synchronization failure - Loss of Sync
05/11/2018 04:04:46 GMT05/11/2018 04:04:46 GMTCritical (3)84000500SYNC Timing Synchronization failure - Loss of Sync
04/11/2018 20:01:15 GMT04/11/2018 20:01:15 GMTError (4)68010302DHCP WAN IP -
04/11/2018 20:00:07 GMT04/11/2018 20:00:07 GMTError (4)68000407TOD established
Time Not EstablishedTime Not EstablishedCritical (3)82000200No Ranging Response received - T3 time-out
  • 5.3K
  • 105
Moderator (Retired)
Message 7 of 7
Hi swift_sport_60
That's great to hear. If there are any further issues let us know and we'll certainly have a look.
