Connection drop and overall poor connection
ben_collinson
Hi All,
I'm quite new to this, so I don't really know what I'm looking at in all honesty. I've been having trouble for a while now, but I thought it might just be all the smart devices I have connected. Furthermore, I've had a look through the forum to see if i can see anything, but I don't even know what to look for. Please see below, does this make sense to anyone, would you recommend I call for an engineer?
22/07/2022 13:11:55Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/07/2022 12:09:28noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;21/07/2022
12:09:28ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;19/07/2022 19:46:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/07/2022 19:46:11criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;19/07/2022 19:46:11Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/07/2022 19:46:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;19/07/2022 19:46:11Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/07/2022 19:46:5criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/07/2022 19:45:15Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/07/2022 19:45:10criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;19/07/2022 19:45:9Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/07/2022 19:45:9criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/07/2022 20:20:1criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/07/2022 08:07:49noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/07/2022 08:07:49ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;14/07/2022 04:09:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/07/2022 18:48:15noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/07/2022 18:48:15ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;09/07/2022 20:51:26criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
8 REPLIES 8
What actual issues are you having and on what devices?
Then are the issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
What Hub model is it? What are the various Hub lights showing/doing when this happens?
If the Hub3, does the base light flash green at all or stay constant white/yellow? Do the wifi lights flash?
Hi jbrennand,
I have the hub3 running in modem mode with a NETGEAR XR500.
Wi-Fi stays connected, but error connected with no internet connection. When I'm on Netflix, it often goes into ultra low resolution as well, but the worst part is when I play PC games and I get kicked out of a game for connecting to the network. I only game lightly at the moment (once or trice a week for periods or 4 hours) and I still seem to get connection errors every time I'm on. I'm at the point of restarting the hub 2 or 3 times a day.
Do a quick check that all of your coax and ethernet cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing, check that all looks good with the outside cabling and wall box (no “staples, etc.,) piercing the cables.
Then can you check for known problems in 2 ways and finally post up all of the Hub data.
______________________________________
Try the “check service,”Area status webpage" (link at top right of this forum)
Then also try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues down to postcode level.
_______________________________________
Navigate to these “pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs page. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again. If character limits are “exceeded” - just do two posts
1227000000-0.238256 qam12
21390000001.738256 qam1
31470000001.740256 qam2
41550000001.540256 qam3
51630000001.540256 qam4
61710000001.540256 qam5
71790000001.240256 qam6
8187000000138256 qam7
9195000000140256 qam8
102030000000.538256 qam9
112110000000.238256 qam10
12219000000040256 qam11
13235000000-0.538256 qam13
14243000000-0.738256 qam14
15251000000-0.938256 qam15
16259000000-138256 qam16
17267000000-0.738256 qam17
18275000000-0.938256 qam18
19283000000-0.940256 qam19
20291000000-0.938256 qam20
21299000000-0.938256 qam21
22307000000-0.938256 qam22
23315000000-0.738256 qam23
24323000000-138256 qam24
1Locked38.650
2Locked38.950
3Locked40.340
4Locked40.350
5Locked40.360
6Locked40.340
7Locked40.360
8Locked38.950
9Locked40.950
10Locked38.980
11Locked38.950
12Locked40.350
13Locked38.930
14Locked38.950
15Locked38.930
16Locked38.600
17Locked38.960
18Locked38.950
19Locked40.340
20Locked38.940
21Locked38.950
22Locked38.980
23Locked38.940
24Locked38.960
15370001444.3512064 qam2
23260000741.8512064 qam5
33940002641.8512064 qam4
44620000942.8512064 qam3
3ATDMA0000
4ATDMA0010
22/07/2022 13:59:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/07/2022 13:51:36noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/07/2022 12:09:28ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
I've reseated the cables and will monitor
All stats looking good. Can you do a BQM too?
________________________________________
If you haven’t already, set up a free, secure and “offlsite” - “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, etc - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” to the “share live graph”. Click the lower link (Share Live Graph) then click generate. Copy the text in the Direct Link box, beware, there may be more text than you can see. On here click the Link icon (2 links chain to the left of the camera icon) In the URL box paste the link you copied and then click OK
