on 03-04-2023 19:11
Hello,
Over the past few weeks my internet has become very sluggish (BR2 area), looking at around 3mb/s download speed on average.
More recently, the signal has become very weak or just cuts off, forcing me to manually restart it, which takes around 30 minutes to come back online. It generally lasts around 24 hours before I have to restart it again. Not sure if relevant, but it always has an orange light.
Any fixes? The hub is fairly old and may need replacement.
Thanks.
on 03-04-2023 19:15
on 04-04-2023 13:37
Hello,
Ethernet and wifi connections are both affected, usually I notice my desktop loses its wired connection and then my mobile does.
It is a hub 3.0
on 04-04-2023 13:53
on 04-04-2023 17:00
Hello,
I have now encountered a different issue.
After restarting it due to reasons mentioned previously, it now shows a solid green light, solid green wifi icon, and flashing green arrows icon. The internet now does not work at all, my mobile detects the signal but there is not connection. I have restarted it multiple times only to encounter the same issue.
I am assuming this is related to my previous issues. I called the 0800 561 0061 hotline and they said no issues detected.
Could someone help please, I cannot use my internet at all now.
thanks
on 04-04-2023 17:04
Ongoing outage at the moment, but some reports are coming in that's it's fixed now?
on 05-04-2023 11:09
Thanks, yes that seemed to be related to the outage.
However the original issue is still persisting. After checking for known network faults which have said there are no issues, I believe this is a malfunction of the hub. Could someone from Virgin Media please get in touch with me about replacing this.
on 05-04-2023 15:25
