on 11-09-2022 11:20
I have recently upgraded my broadband to 1GB and received a Hub5 router. The security encryption used by the Hub5 is wpa2 or wpa3. However the TV only uses wpa, consequently I cannot connect. Anybody got any ideas to solve this?
on 11-09-2022 12:00
If the TV only supports WPA, then you do not want to use it, it’s very unsure. Can you connect it via an Ethernet cable?
on 11-09-2022 12:04
Unfortunately not. Tv is downstairs and router is upstairs! Agree about WPA but cannot do much about that and dont want to bin the TV.
on 11-09-2022 12:18
on 11-09-2022 12:34
How will that help with an unsafe TV connection?
on 11-09-2022 15:41
Hmmm, I'm not sure it will! Although a range extender is helpful its not actually the problem in this case. A physical connection between router and TV is not possible either. Am working around the problem by using an Google HDMI chromecast to connect with a mobile app. But I would prefer to connect WiFi direct to the Tv. Any other ideas anybody?
11-09-2022 15:56 - edited 11-09-2022 15:57
Ask them to replace the Hub5 with a Hub4 ?
Or put the Hub into modem mode and use your own wireless router that offers WPA?
on 11-09-2022 16:26
There will still be WPA which should be avoided.
I would get a simple wireless extender {pod?). Stand it near the TV and connect with ethernet.
on 11-09-2022 17:05
@jpeg1 wrote:How will that help with an unsafe TV connection?
TV has ethernet you connect to the Wi-Fi Range Extender then it connects by WiFi to to the hub
on 11-09-2022 20:47
@AstraNine wrote:I have recently upgraded my broadband to 1GB and received a Hub5 router. The security encryption used by the Hub5 is wpa2 or wpa3. However the TV only uses wpa, consequently I cannot connect. Anybody got any ideas to solve this?
Where did you discover that the TV only uses WPA? Your Samsung UE49KU6400U is a 2016 model and WPA2 was introduced in 2004. There are no security settings for the Samsung TV. We need to get to the bottom of this.
