Connecting Router To Hub4
Mr-Dice
My Hub 4 is in modem mode . I've connected my Orbi router to port 1 .  Is this the correct  port for third party routers  ?
1 REPLY 1
Sephiroth
Any port on the Hub 4 will do (I'm in port 2).   There is a sequence to follow.
1.  Both Hub & router powered off.  Ethernet cable connected between the two.
2.  Power router on and let it settle.
3.  Power Hub 4 on and it will find the router in a state of grace.
4.  The router should indicate that it is connected to the Internet.
Let us know how you get on.
