  • 10
SRainsbury
Message 1 of 7
Combing TV and WiFi hardware
At the moment our broadband cable enters the house at the front and is connected to our Superhub 3. The TV on the other hand comes in at the side and feeds our TIVO box. I want to move the superhub next to the Tiovo, how difficult is this and can they just use the same cable coming into the house?
  • 11.71K
  • 778
  • 3.44K
Message 2 of 7
Re: Combing TV and WiFi hardware
All you need is a splitter and the correct cables
Click to learn more about VIP
Use Kudos to say thanks
  • 10
SRainsbury
Message 3 of 7
Thanks, is this a splitter on the coax?  And if so that would be a couple of short lengths of terminated coax too I guess. Is this something I source myself or do I go through Virgin?
  • 11.71K
  • 778
  • 3.44K
Message 4 of 7
Officially, you go through VM.
Do not under any circumstances use standard coax and splitters.
  • 11.71K
  • 778
  • 3.44K
Message 5 of 7
Also look at the little purple envelope, top right of the forum....
  • 10
SRainsbury
Message 6 of 7
Thanks, I will try that 🙂
  • 4.58K
  • 309
  • 763
Roger_Gooner
Superstar
Message 7 of 7
VM does supply a splitter and two lengths of coaxial cable (I think 3m in length) in the Quickstart pack, so no doubt these can be sent to you.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
