  • 5
ryanicholson1
Message 21 of 25
Re: Changing my IP in modem mode HELP
most helpful answer, I think I'll invest in a VPN and yes there was no question that I would use a paid one. Wouldn't use any free ones. BTW I wasn't on about virgin banning me for using a VPN I was on about the bookie but that must be a myth, I thought I had read it somewhere once.
No point me purchasing a 3rd party router seems a lot of hassle for what I'm changing my IP for
Appreciate the help from everyone 🙂
  • 85
  • 21
het69
Up to speed
Message 22 of 25
Using a different device's MAC address is only an issue on the same network segment, or where proxy-ARP is used.  That's not going to be a problem here.
  • 370
  • 21
  • 36
brooksy79
Fibre optic
Message 23 of 25
As your shopping around for a vpn the best 3 are NordVPN Exressvpn and ipvanish there should be deals around also have a look at https://thatoneprivacysite.net/ it’s a good  comparison of all vpn’s
  • 3.67K
  • 306
  • 1.07K
Dave_cq
Community elder
Message 24 of 25
@brooksy79 wrote:
 1: I recommend using ASUS routers in which the wan ip’s can be changed using MAC ADDRESS CLONING I do this every so often with my 68u as this is handy to stop ddos Attacks.
https://youtu.be/kgvmnKVsiOw
Thanks ever so much for this.  I have the Asus 68U and I had no idea one could spoof the mac address in this way to get the WAN IP changed.  Very useful to know.
********* SuperHub 2ac - Asus rt-ac68u Router - Vivid 100Mbps **********
Electron
  • 11.8K
  • 1.08K
  • 2.56K
griffin
Message 25 of 25
Or you could use Opera browser which has a built in VPN assuming the bookie sites accept connections from VPNs
