Change the LAN IP range Hub 5
Loboexe
Is it possible to configure the HUB 5 in modem mode to use a 172.x.x.x LAN. Everything you buy is on the 192.168.x.x range and therefore more likely to be targeted so can I set the modem to something in the 172.16.x.x  to 172.31.x.x range?
1 REPLY 1
No, you must use 192.168.0.0/24 with all VM hubs. It is not insecure, it’s only local to you and other people on the WAN (internet) side cannot get to your LAN. Other ranges offer nothing more.
