  • 230
  • 24
MikeyMcG
Up to speed
Message 1 of 5
Can't put hub 3 into modem mode
I have been running my hub 3 in modem mode for a while. I was doing some work on my router today so I put the hub back into router mode. Now it won't go back into modem mode. And all my wifi networks are connecting but with no internet connection. At the minute I only have my pc attached to it and I can't even web browse to the settings page. It is on ip address 192.168.0.1 and my pc is on dhcp address 192.168.0.10. So there shouldn't be a problem web browsing to it. I have reset the hub, restarted my pc, tried a different ethernet cable, but no joy.and it has made no difference
Can anyone suggest a fix other than calling and reporting it?
  • 3.07K
  • 172
  • 491
chenks
Wise owl
Message 2 of 5
Re: Can't put hub 3 into modem mode
try a full factory restore.
press and hold the rest pin for at least 60-90 seconds until the hub reboots on its own (don't manually reboot the hub).
then reconnect, log in and put into modem mode.
  • 12.34K
  • 466
  • 1.1K
Message 3 of 5
Why did you go back to router mode? You should of stayed in modem mode.
  • 5.88K
  • 453
  • 986
Hero
Message 4 of 5
Never ever even considered running my Hub3 in modem mode.
There are 10 types of people: those who understand binary and those who don't and F people out of 10 who do not understand hexadecimal
  • 473
  • 26
  • 96
tonycv51
Fibre optic
Message 5 of 5
Try accessing the hub using a phone or tablet connected to the Hub default WiFi and  change it back to modem mode that way (may need to forget the hub network if you've used the device to connect to it previously)
