on 18-06-2022 19:21
I can't hide anymore the SSID after an outage. The option is there but greyed.
I've tried turning off smart wifi to no avail
Thank you!
on 18-06-2022 19:40
Try a 30 second pinhole reset of the hub.
Note that the forum has doubts as to the efficacy of hiding SSIDs https://community.virginmedia.com/t5/Networking-and-WiFi/Hub-4-0-SSID-Broadcasting/m-p/4872679
on 18-06-2022 20:31
Why do you need to hide the SSID? It does not provide any security as all scanners can still see it.
on 20-06-2022 20:46
Hi @AstroTrick thanks for posting and welcome back to our community.
Have you managed to view the link Cardiffman281 provided? If so, has the advice helped you? Please do let us know how things are going.
Lee_R
