Can’t connect to hub3
how to sort this out please? This app is useless. Does it have problem to connect because my speed is poor? I’m on M500 and it’s doing my head in! A2EF4F75-6B60-4C7F-BB84-DA05FBBE2A82.png
  • 11.36K
  • 888
  • 1.45K
Re: Can’t connect to hub3
The Connect App seems to have more bugs than a tramps vest.
My advice ...
Uninstall the Connect App.
Reboot your phone.
Forget about the app.
Factory reset the Hub using this exact method ...
DO NOT DO THIS if the password on the base of the Hub is not legible or missing.
Instructions for Hub 3
Disconnect all unneeded ethernet cables from the rear of the Hub.
With the Hub Powered on use a paperclip or similar (I use a mobile phone SIM Slot tool) and do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Once a steady white and no other lights are illuminated check your system again.
Save your sanity and health still forget about the Connect App.
Use the Hub GUI at 192.168.0.1 in your browser to make Hub Settings changes.
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
