  • 26.02K
  • 1.1K
  • 4.24K
Message 11 of 16
Re: Can not view cctv away from home network
Maybe it was to ignore everything above. that will be your post. his post and everyone post but mine 😛
Click to learn more about VIP
Use Kudos to say thanks
  • 9
athej
Message 12 of 16
I can not set up static address if I do not set hub to DHCP on hub it can not see the DVR
  • 12.45K
  • 472
  • 1.11K
Message 13 of 16
What does the manual say?
  • 9
athej
Message 14 of 16
set up a static address If I do this by turning off dhcp on hub the hub can no longer see the DVR
  • 3.43K
  • 195
  • 559
chenks
Wise owl
Message 15 of 16
you're giving the DVR a static LAN IP, not the hub.
does your DVR have a hard coded static IP address already? if it does then change teh DVR to get a DHCP IP.
and just to clarify - ignore the stupid advice legacy1 gave about having to buy your own router, that just the usual stock answer he/she seems to give for everything regadless of the problem - i think they have a shortcuty key to paste it into every reply they make.
  • 9
athej
Message 16 of 16
Yes I understand If I set the DVR to a static IP the Hub can not see it On connected Devices The only time it can find is switching To DHCP It allways used to work untill new hub installed
