  • 9
athej
Message 1 of 16
Can not view cctv away from home network
I have had a new super hub 3  installed and now I can no longer view over data conection on I phone
I have enabled port forwarding for the port I am using 192.168.0.12  port 20460 The error message
Is The IP address is not accessible works ok when I use over LAN
avtech H264 DVR
can any one Help
  • 4.47K
  • 302
  • 749
Roger_Gooner
Community elder
Message 2 of 16
Re: Can not view cctv away from home network
Does the DVR have a fixed IP address of 192.168.0.12? And you now have a new WAN IP address, once you know it you should be able to get access in a way such as:
http(s)://<my WAN IP addess>:20460
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 9
athej
Message 3 of 16
No it  has a ethernet conection between DVR and virgin hub And hub will only see DVR in DHCP mode not static
Cheers
Alan J
  • 9
athej
Message 4 of 16
Cheers
Alan J
  • 4.47K
  • 302
  • 749
Roger_Gooner
Community elder
Message 5 of 16
If you don't have a fixed IP address for the DVR the port forwarding for the DVR will fail if the DHCP server assigns a different IP address one day to the DVR or the same IP address to another device as 192.168.0.12 is within the hub 3.0's DHCP reservation range which starts from 192.168.0.10. So, what you can do is have the DVR's IP address to something like 192.168.0.8.
  • 12.45K
  • 472
  • 1.11K
Message 6 of 16
Many problems with cctv with the hub so the only way to fix this is to get your own router with 1Gb ports and put the hub in modem mode.
  • 9
athej
Message 7 of 16
How do i set this up
  • 3.43K
  • 195
  • 559
chenks
Wise owl
Message 8 of 16
that's just nonsense, it's NOT the only way to fix this.
  • 3.43K
  • 195
  • 559
chenks
Wise owl
Message 9 of 16
ignoring the stupid advice above......
give your DVR a static LAN IP address
set up a port forward on the hub to point to the static IP of the DVR
  • 12.45K
  • 472
  • 1.11K
Message 10 of 16
"ignoring the stupid advice above......"
Well the above would be your post so that would be to ignore your stupid advice!
