on 06-07-2021 12:25
Hello,
My cable modem keeps rebooting itself - maybe because its losing the connection. I am working from home and its extremely disruptive being dropped from meetings 10 minutes at a time while it reconnects.
I also noticed that I seem to be on 30mbit even though I'm paying a lot, but the minimum available on the site seems to be 100mbit now. Is is time for my equipment to be upgraded?
Thanks in advance
Answered! Go to Answer
on 06-07-2021 15:55
I think I'm having the same problem as you, I contacted Virgin via chat and they asked me to separate my 2.4GHz 5GHz wifi network, I did that but it didn't solve my problem, minutes after I ended the chat with support my connection keeps dropping constantly. It all started last night and so far it remains the same.
on 06-07-2021 16:03
Acquired Downstream Channel (Hz) | 331000000 | Locked |
Ranged Upstream Channel (Hz) | 60300000 | Locked |
Provisioning State | Online |
1 | 331000000 | 8.9 | 40 | 256 qam | 25 |
2 | 203000000 | 6.3 | 38 | 256 qam | 9 |
3 | 211000000 | 7.1 | 38 | 256 qam | 10 |
4 | 219000000 | 7 | 38 | 256 qam | 11 |
5 | 227000000 | 6.9 | 38 | 256 qam | 12 |
6 | 235000000 | 7 | 38 | 256 qam | 13 |
7 | 243000000 | 7 | 38 | 256 qam | 14 |
8 | 251000000 | 6.9 | 38 | 256 qam | 15 |
9 | 259000000 | 6 | 38 | 256 qam | 16 |
10 | 267000000 | 6.1 | 38 | 256 qam | 17 |
11 | 275000000 | 6.4 | 38 | 256 qam | 18 |
12 | 283000000 | 7.4 | 38 | 256 qam | 19 |
13 | 291000000 | 8 | 38 | 256 qam | 20 |
14 | 299000000 | 8.8 | 38 | 256 qam | 21 |
15 | 307000000 | 8.9 | 38 | 256 qam | 22 |
16 | 315000000 | 9 | 38 | 256 qam | 23 |
17 | 323000000 | 8.9 | 38 | 256 qam | 24 |
18 | 339000000 | 9 | 38 | 256 qam | 26 |
19 | 347000000 | 9.3 | 38 | 256 qam | 27 |
20 | 355000000 | 9 | 38 | 256 qam | 28 |
21 | 363000000 | 8.8 | 40 | 256 qam | 29 |
22 | 371000000 | 8.9 | 40 | 256 qam | 30 |
23 | 379000000 | 9 | 38 | 256 qam | 31 |
24 | 387000000 | 9.1 | 40 | 256 qam | 32 |
1 | Locked | 40.3 | 0 | 0 |
2 | Locked | 38.6 | 0 | 0 |
3 | Locked | 38.6 | 0 | 0 |
4 | Locked | 38.6 | 5 | 0 |
5 | Locked | 38.6 | 5 | 0 |
6 | Locked | 38.9 | 4 | 0 |
7 | Locked | 38.6 | 4 | 0 |
8 | Locked | 38.6 | 6 | 0 |
9 | Locked | 38.6 | 0 | 0 |
10 | Locked | 38.9 | 0 | 0 |
11 | Locked | 38.9 | 1 | 0 |
12 | Locked | 38.6 | 7 | 0 |
13 | Locked | 38.6 | 5 | 0 |
14 | Locked | 38.9 | 5 | 0 |
15 | Locked | 38.6 | 5 | 0 |
16 | Locked | 38.9 | 5 | 0 |
17 | Locked | 38.9 | 5 | 0 |
18 | Locked | 38.9 | 0 | 0 |
19 | Locked | 38.9 | 19 | 0 |
20 | Locked | 38.9 | 17 | 0 |
21 | Locked | 40.3 | 19 | 0 |
22 | Locked | 40.3 | 5 | 0 |
23 | Locked | 38.9 | 5 | 0 |
24 | Locked | 40.3 | 0 | 0 |
1 | 60300000 | 48.8 | 5120 | 64 qam | 1 |
2 | 46200000 | 48.3 | 5120 | 64 qam | 3 |
3 | 39400035 | 48 | 5120 | 64 qam | 4 |
4 | 53700000 | 48.5 | 5120 | 64 qam | 2 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 06-07-2021 16:03
General Configuration
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | cmreg-vmdg505-bbt062+voc-b.cm |
SFID | 326070 |
Max Traffic Rate | 402500089 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
Primary Upstream Service Flow
SFID | 326069 |
Max Traffic Rate | 38500089 |
Max Concatenated Burst | 42600 |
Scheduling Type | BestEffort |
06/07/2021 14:22:33 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:39 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/07/2021 13:57:27 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/07/2021 13:27:42 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:37 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/07/2021 12:32:19 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:40 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/07/2021 12:21:36 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:27 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/07/2021 16:05:42 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/07/2021 08:54:41 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/07/2021 08:50:41 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/07/2021 08:50:41 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/07/2021 08:50:41 | critical | Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/07/2021 08:49:57 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/07/2021 08:49:53 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 06-07-2021 16:18
06-07-2021 16:25 - edited 06-07-2021 16:27
on 06-07-2021 16:27
@DannyF wrote:I don't think I'm too far from the box - a couple of streets away I think.
No more reboots today so far. Here is the monitor for today since I posted here.
Looks a bit spiky!
on 06-07-2021 16:55
I don't know what else to do, my broadband just doesn't work.
on 07-07-2021 06:27
Thanks for your help so far. What do you think I can do to improve things? Would I need to phone customer service? They don’t seem to be following here. I thought they used to be active here
on 07-07-2021 06:42
@gilbertouk wrote:I don't know what else to do, my broadband just doesn't work.
You should start your own thread. - That way people will be able to help you!
on 07-07-2021 06:43
@DannyF wrote:Thanks for your help so far. What do you think I can do to improve things? Would I need to phone customer service? They don’t seem to be following here. I thought they used to be active here
There's not much you can do to be honest - Calling customer services can be really frustrating but it *can* work.
VM Staff usually pick these up in a day or so!
