Markovitch
Cable fitting to broadband hub
I accidentally knocked over my broadband  hub, and the metal fixing/junction at the end of the cable is irreparable. It still works as the wire is showing/isible and slots into the hole in the hubbut if u need to move thd hub it falls out. I rang Virgin and they won't t/don't supply a replacement cable, which is rather annoying (I need one approx 2 metres long) Any help or suggestions would be most welcomed - thanks
g0akc
  • 606
  • 62
  • 123
Rising star
Re: Cable fitting to broadband hub
PM sent
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
