on 02-03-2022 13:18
Hopefully somebody can help please?
We have an issue, where randomly it appears that we loose incoming internet service/broadband signal. There is no issue with the Wi-Fi signal that never seems to falter other than being a bit weedy. Devices can be connected to the network but randomly for a short period we have no internet.
What regularly also happens and is most noticeable is during a phone call using Wi-fi calling, after a random amount of time on a call the signal will drop out and then the phone tries to connect to a poor 3g signal. Frequently the call will be lost but if not eventulally it will sometimes reconnects to Wi-fi calling.
It is also noticeable on some devices in the house also when internet browsing the signal drops out and it states not internet activity but Wi Fi is active.
Im sure this is a regular occurance and has been happening for several years.
I believe this is probably a problem stemming from outside the house in a local cabinet maybe?
Has anybody experienced this? and or can anybody help?
Answered! Go to Answer
on 02-03-2022 16:36
on 02-03-2022 16:36
on 02-03-2022 18:16
John,
Thanks for your email.
The unit is a Super Hub 3 but as to what lights etc are on when it occurs I couldnt say as router in in a room that is unoccupied. When we have an issue, it has usually returned to normal by the time we get to the router.
Also we run it with one PC hardwire and the rest of the equipment uses the Wi-Fi
Thanks for the advise on the Broadband Quality Monitor, I have just set that up.
As requested, here is a copy of the of the satus info from the router
Thanks fo ryour help.
Steve
Downstream 1
1 | 267000000 | 5 | 40 | 256 qam | 17 |
2 | 275000000 | 5 | 40 | 256 qam | 18 |
3 | 283000000 | 5.3 | 40 | 256 qam | 19 |
4 | 291000000 | 5.1 | 40 | 256 qam | 20 |
5 | 299000000 | 5.4 | 40 | 256 qam | 21 |
6 | 307000000 | 5.4 | 40 | 256 qam | 22 |
7 | 315000000 | 5.3 | 40 | 256 qam | 23 |
8 | 323000000 | 5.1 | 40 | 256 qam | 24 |
9 | 331000000 | 5 | 40 | 256 qam | 25 |
10 | 339000000 | 5 | 40 | 256 qam | 26 |
11 | 347000000 | 4.5 | 40 | 256 qam | 27 |
12 | 355000000 | 4.5 | 40 | 256 qam | 28 |
13 | 363000000 | 4 | 40 | 256 qam | 29 |
14 | 371000000 | 3.9 | 40 | 256 qam | 30 |
15 | 379000000 | 4 | 40 | 256 qam | 31 |
16 | 387000000 | 3.7 | 40 | 256 qam | 32 |
17 | 395000000 | 3.9 | 40 | 256 qam | 33 |
18 | 403000000 | 3.7 | 40 | 256 qam | 34 |
19 | 411000000 | 3.9 | 40 | 256 qam | 35 |
20 | 419000000 | 3.5 | 40 | 256 qam | 36 |
21 | 427000000 | 3.5 | 40 | 256 qam | 37 |
22 | 435000000 | 3.2 | 40 | 256 qam | 38 |
23 | 443000000 | 2.9 | 40 | 256 qam | 39 |
24 | 451000000 | 3 | 40 | 256 qam | 40 |
Table 2
1 | Locked | 40.3 | 1585 | 573 |
2 | Locked | 40.9 | 982 | 701 |
3 | Locked | 40.3 | 982 | 833 |
4 | Locked | 40.3 | 1270 | 884 |
5 | Locked | 40.3 | 1099 | 1025 |
6 | Locked | 40.9 | 1122 | 1063 |
7 | Locked | 40.9 | 922 | 1055 |
8 | Locked | 40.9 | 955 | 1057 |
9 | Locked | 40.3 | 1627 | 1275 |
10 | Locked | 40.9 | 1125 | 1024 |
11 | Locked | 40.9 | 1422 | 952 |
12 | Locked | 40.9 | 1359 | 1073 |
13 | Locked | 40.3 | 1667 | 1160 |
14 | Locked | 40.3 | 1713 | 885 |
15 | Locked | 40.3 | 1393 | 750 |
16 | Locked | 40.3 | 1330 | 718 |
17 | Locked | 40.9 | 1210 | 672 |
18 | Locked | 40.3 | 1448 | 631 |
19 | Locked | 40.3 | 1493 | 617 |
20 | Locked | 40.9 | 1221 | 499 |
21 | Locked | 40.3 | 1886 | 519 |
22 | Locked | 40.9 | 1342 | 511 |
23 | Locked | 40.9 | 1349 | 412 |
24 | Locked | 40.3 | 924 | 398 |
Upstream 1
hannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1 | 46200000 | 46 | 5120 | 64 qam | 6 |
2 | 60300000 | 46.8 | 5120 | 64 qam | 4 |
3 | 53700025 | 46 | 5120 | 64 qam | 5 |
4 | 39400005 | 46 | 5120 | 64 qam | 8 |
Upstream 2
1 | ATDMA | 0 | 0 | 9 | 0 |
2 | ATDMA | 0 | 0 | 5 | 0 |
3 | ATDMA | 0 | 0 | 6 | 0 |
4 | ATDMA | 0 | 0 | 8 | 0 |
on 02-03-2022 18:19
Hi John,
Network Log wouldnt go in one email (exceeded word count) please see below:
This is as much as would send
Thanks.
02/03/2022 12:53:33 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/03/2022 12:45:6 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/03/2022 12:44:2 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/03/2022 12:42:12 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/03/2022 13:50:6 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/02/2022 11:53:55 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/02/2022 13:50:6 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/02/2022 06:21:43 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/02/2022 01:50:6 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/02/2022 15:24:48 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/02/2022 01:50:6 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 02-03-2022 18:22
This happens me on a regular basis. Very common the last few days.
The router itself is losing internet connection. Close to dumping vodafone now.
02-03-2022 18:41 - edited 02-03-2022 18:44
Power levels are all fine - errors might be an issue - but I think the stats need resetting - so can you do this and post up the BQM link
________________________________________
Switch the Hub off and unplug it from the mains supply for five minutes. Whilst it's off, do a quick check that all of your coax cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing, check that all looks good with the outside cabling and wall box (no “staples, etc.,) piercing the cables.. Then switch the Hub back on and leave ~5 minutes
When all done, check back in the settings and ensure that the RS error counts and T3 errors have all reset to 0. Then check every hour or so to see if they start reappearing - they shouldn't.
Check every few hours/day and see if they start building up.
on 03-03-2022 13:08
Hi Jon,
Thanks for getting back to me with the info and advice.
I will have a go at what you suggest but it may take me a few days before I have chance.
I will let you know when I have tried what you suggest.
Steve
