  • 13
Message 1 of 11
Broadband router does not connect intermittently
Hi, my broadband router seems to have connection issues intermittently and devices connected show no internet signal. Then again after 5-10 minutes, the internet seems to get connected again.
My router is almost 2.5 years old and thinks that age has affected the performance. Calling support, get a normal speech that everything seems fine on your router but then keep telling them that it isn't functioning properly.
Can someone from support team help me. Have been with Virgin media for last 6 years but this is pushing me to check for alternatives.
  • 11.83K
  • 925
  • 1.52K
Message 2 of 11
Re: Broadband router does not connect intermittently
Mike Robinson
  • 11.83K
  • 925
  • 1.52K
Message 3 of 11
Can you please
Mike Robinson
Message 4 of 11
Hi Mike
I have had the same issues myself, i posted a week or so ago about it but didnt make any progress.
Do you mind if i post my BQM results on here?
  • 13
Message 5 of 11
1Locked38.950
2Locked38.650
3Locked38.6300
4Locked38.6430
5Locked38.950
6Locked38.900
7Locked38.960
8Locked38.660
9Locked38.970
10Locked38.660
11Locked38.9220
12Locked38.670
13Locked38.6150
14Locked38.620
15Locked38.900
16Locked38.910
17Locked38.660
18Locked38.940
19Locked38.960
20Locked38.600
21Locked38.950
22Locked38.600
23Locked38.650
24Locked38.900
  • 13
Message 6 of 11
15369998354512064 qam2
26029994754512064 qam1
  • 13
Message 7 of 11
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
7dsfd;kfoA,.iyewrkldJKDHS
SFID622
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID621
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
  • 13
Message 8 of 11
16/11/2020 09:28:33noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/11/2020 09:27:43Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/11/2020 00:18:44criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 11:01:3criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 09:47:38noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 09:47:38ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 09:17:36noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 09:17:36ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 00:53:14criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 21:17:36noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 21:17:36ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 20:43:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 13:32:58criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 08:55:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 17:06:57noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 17:06:57ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 14:48:57criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 02:37:12noticeSW download Successful - Via NMS
09/11/2020 02:35:1noticeSW Download INIT - Via NMS
06/11/2020 20:02:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 13
Message 9 of 11
My BMQ results -
https://www.thinkbroadband.com/broadband/monitoring/quality/share/77996e05c5efad6709aa4cac2bd34dde5cd5ab28-16-11-2020
  • 11.83K
  • 925
  • 1.52K
Message 10 of 11
You only have two Upstream Channels, we expect to see four.
The Power Levels on those two channels are too high.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Mike Robinson
