on 30-12-2021 17:50
After a bit of help in looking to move hub to another location in the room
A new longer cable from wall socket to hub will be required- how do I go about this?i
I would welcome some advice as to how go about this.
Thank you
Stephen
Answered! Go to Answer
on 30-12-2021 18:06
@gary_dexter wrote:
You’d need to request a longer cable but it would require an engineer visit at a cost of £99 to check power levels etc.
The cost is now a reasonable £25, the old cost was £99.
on 30-12-2021 18:03
on 30-12-2021 18:06
on 30-12-2021 22:54
Thank you
