  • 7
LiamW
Message 1 of 10
Broadband lag issues
 Hello,
Been having constant issues on the Xbox using WiFi and Ethernet. When gaming online there are constant lag issues, and when watching films on Netflix the picture quality often goes very poor.
I have ran a diagnostic test above and it shows problems with no actual explanation.
Any help would be greatly appreciated.
  • 19.32K
  • 1.68K
  • 4.23K
Message 2 of 10
Re: Broadband lag issues
Would need to check the signal levels if could go to http://192.168.0.1 or if using modem mode http://192.168.100.1 clicking router status top right or bottom of page depending on hub [no need to login - depending on hub] and if could copy/paste the downstream, upstream, network log, don't worry about the formatting we can easily read it.. try and avoid using screen shots..
Click to learn more about VIP
Use Kudos to say thanks
  • 7
LiamW
Message 3 of 10
139500000011.140256 qam27
24030000001140256 qam28
33870000001140256 qam26
43790000001138256 qam25
53230000009.640256 qam24
63150000009.538256 qam23
73070000009.538256 qam22
82990000009.438256 qam21
92910000009.338256 qam20
102830000009.138256 qam19
11275000000940256 qam18
12267000000940256 qam17
132590000009.138256 qam16
142510000009.138256 qam15
152430000009.438256 qam14
162350000009.438256 qam13
172270000009.438256 qam12
182190000009.538256 qam11
192110000009.638256 qam10
202030000009.540256 qam9
211950000009.540256 qam8
221870000009.538256 qam7
231790000009.540256 qam6
241710000009.538256 qam5
1Locked40.316301462
2Locked40.316451527
3Locked40.317011425
4Locked38.616601669
5Locked40.316981874
6Locked38.917281754
7Locked38.916391893
8Locked38.916211625
9Locked38.615711346
10Locked38.916681419
11Locked40.914921480
12Locked40.313281284
13Locked38.912551267
14Locked38.912371139
15Locked38.912841371
16Locked38.611211518
17Locked38.916115245
18Locked38.924735275
19Locked38.911892146
20Locked40.314322365
21Locked40.912582690
22Locked38.612573523
23Locked40.313043392
24Locked38.913122943
  • 7
LiamW
Message 4 of 10
13940000041.8512064 qam4
26030000041.8512064 qam1
35370000041.8512064 qam2
44620000041.5512064 qam3
3ATDMA0030
4ATDMA0000
  • 7
LiamW
Message 5 of 10
2018-12-08 07:55:05.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-12-12 01:23:27.00ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-12-12 05:17:51.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-12-12 16:18:16.00ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-12-13 07:13:09.00ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-12-13 09:29:48.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-12-16 12:46:22.00ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-12-16 20:12:18.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-12-16 23:20:54.00ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-12-17 09:55:30.00ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-12-18 09:19:20.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-12-21 19:18:52.00ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-12-22 04:33:15.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-12-22 09:41:09.00ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-12-23 00:03:29.00ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-12-24 00:26:43.00Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-12-24 17:49:18.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-12-25 16:55:46.00Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-12-25 16:55:47.00criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-12-25 16:55:47.00Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 7
LiamW
Message 6 of 10
Sorry, a lot of the data started out, it contains this:
  • 19.32K
  • 1.68K
  • 4.23K
Message 7 of 10
downstream power showing too high, would make sure all white cable (coax) are finger tight, is there any attnetuors attached to the coax cable might say +5dbmv forward path.
  • 7
LiamW
Message 8 of 10
Hello,
All cables are as tight as they can be, and there seems to be no attenuators, just the plain cable that was first delivered with the starter kit.
  • 19.32K
  • 1.68K
  • 4.23K
Message 9 of 10
would more than likely would need a tech attend to adjust these, can wait around a week for the forum staff to arrange, or could call faults via 150 / 0345 454 11111
  • 7
LiamW
Message 10 of 10
Purchased a 6db attenuator and it seems to have sorted the issue.
Thanks for your help paultechy
