on 23-07-2021 13:54
Hi broadband keeps shutting down its been going on for weeks now, been in touch with virgin and been told it's Apple iPhone and blind spots in the house.
I have brought a mesh WiFi and still have problems, it shut down today all I got from virgin was he wanted to sell me WiFi extenders, how do I get this fixed.
Kind Regards
Neil Allen
Answered! Go to Answer
23-07-2021 14:02 - edited 23-07-2021 14:04
Firstly... Are the issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check to help diagnose whether it is just a wifi issue or it could be network connection related?
What are the various Hub lights showing/doing when this happens?
Also what make and model of Mesh system did you get and did you set it up with the Hub in modem mode and using the "correct sequence"?
on 23-07-2021 18:40
Hi John started playing up before we had WiFi extender. I put it down to 02 merger with virgin.
It goes off between 1pm and 2pm also 1am and 2am and sometimes at 8am.
We use nowtv and when the system goes down it takes up to 15 minutes to start working.
The mesh WiFi is tp-link from pc world, it works with any network, I have had virgin for years but never had trouble before.
We only have WiFi in the house
Kind Regards.
Neil Allen
on 23-07-2021 18:46
Hi John
100 fibre broadband
Thanks Neil
on 23-07-2021 18:51
on 24-07-2021 09:08
Hi John
Kind Regards
Neil Allen
on 26-07-2021 08:36
Hi NeilAllen.
Thanks for your post.
Sorry, you have been having issues, I have located your account and can see your hub is unreachable can you ensure this is switched on and in the open.
If you could answer @jbrennand questions so the community can best assist you with your issues 🙂
Zoie
