on 08-09-2021 16:29
Over the past few weeks I have noticed at certain times in the day my broadband drops and becomes very unresponsive. For the last few days this has been around 12 o'clock.
I have performed a factory reset, which appeared to help a bit, but upon reading the forum it would appear my issues might be worth further investigation. I Have run a Broadband Quality monitor for today which supports the issues I have experienced. I would say that I was not at home today when it happened.
I will try to post the hub connection data as well
Thanks for any thoughts guidance next steps in advance
Neil
Answered! Go to Answer
on 08-09-2021 21:45
on 09-09-2021 09:46
Morning All,
this mornings data
1 | 411000000 | 8 | 37 | 256 qam | 33 |
2 | 235000000 | 8 | 40 | 256 qam | 13 |
3 | 243000000 | 8 | 40 | 256 qam | 14 |
4 | 251000000 | 8 | 40 | 256 qam | 15 |
5 | 259000000 | 8 | 40 | 256 qam | 16 |
6 | 267000000 | 8 | 40 | 256 qam | 17 |
7 | 275000000 | 8 | 40 | 256 qam | 18 |
8 | 283000000 | 8.1 | 40 | 256 qam | 19 |
9 | 291000000 | 8.4 | 40 | 256 qam | 20 |
10 | 299000000 | 8.5 | 40 | 256 qam | 21 |
11 | 307000000 | 8.5 | 40 | 256 qam | 22 |
12 | 315000000 | 8.4 | 40 | 256 qam | 23 |
13 | 323000000 | 8.1 | 38 | 256 qam | 24 |
14 | 347000000 | 8.4 | 40 | 256 qam | 25 |
15 | 355000000 | 8.4 | 40 | 256 qam | 26 |
16 | 363000000 | 8.3 | 38 | 256 qam | 27 |
17 | 371000000 | 8 | 38 | 256 qam | 28 |
18 | 379000000 | 8 | 38 | 256 qam | 29 |
19 | 387000000 | 7.9 | 38 | 256 qam | 30 |
20 | 395000000 | 8 | 38 | 256 qam | 31 |
21 | 403000000 | 8 | 38 | 256 qam | 32 |
22 | 419000000 | 8 | 38 | 256 qam | 34 |
23 | 427000000 | 8 | 40 | 256 qam | 35 |
24 | 435000000 | 7.6 | 40 | 256 qam | 36 |
1 | Locked | 37.6 | 161 | 0 |
2 | Locked | 40.3 | 17 | 0 |
3 | Locked | 40.3 | 24 | 0 |
4 | Locked | 40.3 | 38 | 0 |
5 | Locked | 40.3 | 45 | 0 |
6 | Locked | 40.3 | 38 | 0 |
7 | Locked | 40.3 | 40 | 0 |
8 | Locked | 40.3 | 46 | 0 |
9 | Locked | 40.3 | 50 | 0 |
10 | Locked | 40.3 | 61 | 0 |
11 | Locked | 40.9 | 43 | 0 |
12 | Locked | 40.3 | 59 | 0 |
13 | Locked | 38.9 | 81 | 0 |
14 | Locked | 40.3 | 76 | 0 |
15 | Locked | 40.9 | 86 | 0 |
16 | Locked | 38.9 | 105 | 0 |
17 | Locked | 38.6 | 133 | 0 |
18 | Locked | 38.6 | 143 | 0 |
19 | Locked | 38.6 | 184 | 0 |
20 | Locked | 38.6 | 139 | 0 |
21 | Locked | 38.6 | 151 | 0 |
22 | Locked | 38.6 | 148 | 0 |
23 | Locked | 40.9 | 90 | 0 |
24 | Locked | 40.3 | 109 | 0 |
1 | 46199996 | 37.5 | 5120 | 64 qam | 3 |
2 | 25799986 | 37.5 | 5120 | 64 qam | 6 |
3 | 32599961 | 37.5 | 5120 | 64 qam | 5 |
4 | 39399979 | 37.5 | 5120 | 64 qam | 4 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
No new notes on the network log
on 09-09-2021 10:10
on 09-09-2021 13:44
So we had the normal lunchtime issues again.
Statistics and Quality monitor chart attached in a couple of messages
9 | 291000000 | 8.5 | 40 | 256 qam | 20 |
10 | 299000000 | 8.6 | 40 | 256 qam | 21 |
14 | 347000000 | 8.5 | 40 | 256 qam | 25 |
1 | Locked | 37.6 | 289 | 10675 |
2 | Locked | 40.3 | 25 | 0 |
3 | Locked | 40.9 | 28 | 0 |
4 | Locked | 40.3 | 51 | 0 |
5 | Locked | 40.3 | 57 | 0 |
6 | Locked | 40.3 | 56 | 0 |
7 | Locked | 40.3 | 58 | 0 |
8 | Locked | 40.3 | 66 | 0 |
9 | Locked | 40.3 | 65 | 0 |
10 | Locked | 40.3 | 78 | 0 |
11 | Locked | 40.3 | 65 | 0 |
12 | Locked | 40.3 | 84 | 0 |
13 | Locked | 38.9 | 110 | 0 |
14 | Locked | 40.3 | 98 | 0 |
15 | Locked | 40.9 | 109 | 0 |
16 | Locked | 38.9 | 140 | 0 |
17 | Locked | 38.6 | 168 | 0 |
18 | Locked | 38.6 | 201 | 0 |
19 | Locked | 38.6 | 241 | 0 |
20 | Locked | 38.6 | 191 | 0 |
21 | Locked | 38.6 | 196 | 0 |
22 | Locked | 38.6 | 192 | 0 |
23 | Locked | 40.3 | 119 | 0 |
24 | Locked | 40.9 | 153 | 0 |
2 | 25800000 | 37.5 | 5120 | 64 qam | 6 |
on 09-09-2021 13:44
09/09/2021 12:36:58 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 11:37:12 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/09/2021 15:31:33 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/09/2021 11:59:43 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/09/2021 11:37:6 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/09/2021 23:12:16 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/09/2021 17:49:17 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/09/2021 16:35:34 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/09/2021 15:26:42 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/09/2021 11:37:2 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/09/2021 12:32:35 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/09/2021 12:31:2 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/09/2021 12:31:2 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/09/2021 11:37:0 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
03/09/2021 20:03:44 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
03/09/2021 11:37:2 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
03/09/2021 03:21:40 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
03/09/2021 00:31:2 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
03/09/2021 00:31:2 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
30/08/2021 13:37:0 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
Is there anything further that can be done?
on 09-09-2021 14:41
on 09-09-2021 15:19
Eeeek, that doesn't sound great. I assume the radio network?
Would the ingress be somewhere from the street into the house or after the cables enter the house. We are some distance from the roads (closest road would be something like 80m). We will have quite a long run from the Virgin Street box but not sure where else I might be able to investigate.
Neil
on 09-09-2021 15:21
on 10-09-2021 09:54
Further checking the broadband quality report indicated I had a couple more outages yesterday evening and this morning,
I guess what I am reading is that there is nothing that can be practically done to stop this happening and I have to live with it?
on 10-09-2021 10:04
