on 08-09-2021 16:29
Over the past few weeks I have noticed at certain times in the day my broadband drops and becomes very unresponsive. For the last few days this has been around 12 o'clock.
I have performed a factory reset, which appeared to help a bit, but upon reading the forum it would appear my issues might be worth further investigation. I Have run a Broadband Quality monitor for today which supports the issues I have experienced. I would say that I was not at home today when it happened.
I will try to post the hub connection data as well
Thanks for any thoughts guidance next steps in advance
Neil
Answered! Go to Answer
on 09-09-2021 14:41
on 08-09-2021 16:33
1 411000000 7.5 37 256 qam 33
2 235000000 7.5 40 256 qam 13
3 243000000 7.5 40 256 qam 14
4 251000000 7.4 40 256 qam 15
5 259000000 7.4 40 256 qam 16
6 267000000 7.4 40 256 qam 17
7 275000000 7.4 40 256 qam 18
8 283000000 7.5 40 256 qam 19
9 291000000 7.9 40 256 qam 20
10 299000000 8 38 256 qam 21
11 307000000 7.9 40 256 qam 22
12 315000000 7.8 40 256 qam 23
13 323000000 7.6 38 256 qam 24
14 347000000 7.9 40 256 qam 25
15 355000000 7.8 40 256 qam 26
16 363000000 7.6 38 256 qam 27
17 371000000 7.5 38 256 qam 28
18 379000000 7.4 38 256 qam 29
19 387000000 7.3 38 256 qam 30
20 395000000 7.4 38 256 qam 31
21 403000000 7.4 38 256 qam 32
22 419000000 7.4 38 256 qam 34
23 427000000 7.4 40 256 qam 35
24 435000000 7 40 256 qam 36
1 Locked 37.6 6339 302884
2 Locked 40.3 541 0
3 Locked 40.3 787 0
4 Locked 40.3 1003 0
5 Locked 40.3 1254 0
6 Locked 40.3 1457 0
7 Locked 40.3 1820 0
8 Locked 40.3 1727 0
9 Locked 40.3 1662 0
10 Locked 38.9 2026 0
11 Locked 40.3 1991 0
12 Locked 40.3 2324 0
13 Locked 38.6 2960 0
14 Locked 40.3 2723 0
15 Locked 40.9 2610 0
16 Locked 38.9 3788 0
17 Locked 38.9 4726 0
18 Locked 38.6 5509 0
19 Locked 38.6 6121 0
20 Locked 38.6 5834 0
21 Locked 38.6 5378 0
22 Locked 38.6 5354 0
23 Locked 40.3 3688 0
24 Locked 40.9 3898 0
on 08-09-2021 16:34
1 46200000 37.5 5120 64 qam 3
2 25800000 37 5120 64 qam 6
3 32600000 37.5 5120 64 qam 5
4 39400000 37.5 5120 64 qam 4
1 ATDMA 0 0 1 0
2 ATDMA 0 0 5 0
3 ATDMA 0 0 3 0
4 ATDMA 0 0 3 0
on 08-09-2021 16:35
08/09/2021 15:31:33 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/09/2021 11:59:43 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/09/2021 11:37:6 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/09/2021 23:12:16 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/09/2021 17:49:17 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/09/2021 16:35:34 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/09/2021 15:26:42 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/09/2021 11:37:2 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/09/2021 12:32:35 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/09/2021 12:31:2 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/09/2021 12:31:2 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/09/2021 11:37:0 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2021 20:03:44 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2021 11:37:2 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2021 03:21:40 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2021 00:31:2 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2021 00:31:2 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/08/2021 13:37:0 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/08/2021 12:31:1 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/08/2021 12:31:1 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
on 08-09-2021 16:37
on 08-09-2021 16:44
Thanks John
Appreciate the rapid response.
I think the network logs should be there
I will follow your guidance and get back to you.....
Neil
on 08-09-2021 16:51
on 08-09-2021 17:18
Updated post checks and switching router on / off.
Will continue to monitor
1 411000000 7.5 38 256 qam 33
4 251000000 7.5 40 256 qam 15
5 259000000 7.5 40 256 qam 16
6 267000000 7.5 40 256 qam 17
7 275000000 7.5 40 256 qam 18
8 283000000 7.6 40 256 qam 19
9 291000000 8 40 256 qam 20
10 299000000 8.1 40 256 qam 21
11 307000000 8 40 256 qam 22
12 315000000 7.9 40 256 qam 23
13 323000000 7.6 40 256 qam 24
14 347000000 8 40 256 qam 25
15 355000000 8 40 256 qam 26
16 363000000 7.8 40 256 qam 27
18 379000000 7.5 38 256 qam 29
19 387000000 7.5 38 256 qam 30
20 395000000 7.5 38 256 qam 31
21 403000000 7.5 38 256 qam 32
22 419000000 7.5 38 256 qam 34
23 427000000 7.5 40 256 qam 35
24 435000000 7.1 40 256 qam 36
1 Locked 38.6 7 0
2 Locked 40.3 5 0
3 Locked 40.9 6 0
4 Locked 40.9 5 0
5 Locked 40.3 2 0
6 Locked 40.3 6 0
7 Locked 40.3 6 0
8 Locked 40.9 5 0
9 Locked 40.3 4 0
10 Locked 40.3 6 0
11 Locked 40.3 5 0
12 Locked 40.3 4 0
13 Locked 40.3 5 0
14 Locked 40.9 6 0
15 Locked 40.3 5 0
16 Locked 40.9 6 0
17 Locked 38.9 7 0
18 Locked 38.9 4 0
19 Locked 38.6 7 0
20 Locked 38.6 4 0
21 Locked 38.6 5 0
22 Locked 38.6 8 0
23 Locked 40.3 5 0
24 Locked 40.9 7 0
1 46199996 37.5 5120 64 qam 3
2 25799986 37.5 5120 64 qam 6
3 32599961 37.5 5120 64 qam 5
4 39399979 37.5 5120 64 qam 4
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
on 08-09-2021 18:57
You can always get a few Pre RS errors, but yours look too high for the time period. Please post another set of stats in a couple of hours.
on 08-09-2021 21:40
hi Tudor
stats as of 21:38 today 🙂
1 411000000 7.8 37 256 qam 33
2 235000000 7.8 40 256 qam 13
3 243000000 7.8 40 256 qam 14
4 251000000 7.6 40 256 qam 15
5 259000000 7.6 40 256 qam 16
6 267000000 7.6 40 256 qam 17
7 275000000 7.6 40 256 qam 18
8 283000000 7.9 40 256 qam 19
10 299000000 8.4 40 256 qam 21
11 307000000 8.1 40 256 qam 22
12 315000000 8.1 40 256 qam 23
13 323000000 8 40 256 qam 24
14 347000000 8.1 40 256 qam 25
15 355000000 8.1 40 256 qam 26
16 363000000 8 40 256 qam 27
17 371000000 7.8 38 256 qam 28
18 379000000 7.8 38 256 qam 29
19 387000000 7.6 38 256 qam 30
20 395000000 7.8 38 256 qam 31
21 403000000 7.8 38 256 qam 32
22 419000000 7.6 38 256 qam 34
23 427000000 7.6 40 256 qam 35
24 435000000 7.4 40 256 qam 36
1 Locked 37.6 21 0
2 Locked 40.3 8 0
3 Locked 40.3 9 0
4 Locked 40.3 11 0
5 Locked 40.9 9 0
6 Locked 40.3 8 0
7 Locked 40.3 9 0
8 Locked 40.3 12 0
9 Locked 40.3 11 0
10 Locked 40.3 15 0
11 Locked 40.3 7 0
12 Locked 40.9 6 0
13 Locked 40.3 14 0
14 Locked 40.9 11 0
15 Locked 40.3 16 0
16 Locked 40.3 11 0
17 Locked 38.9 30 0
18 Locked 38.9 17 0
19 Locked 38.9 17 0
20 Locked 38.6 17 0
21 Locked 38.6 16 0
22 Locked 38.6 19 0
23 Locked 40.3 12 0
24 Locked 40.9 25 0
1 | 46199996 | 37.5 | 5120 | 64 qam | 3 |
2 | 25799986 | 37.5 | 5120 | 64 qam | 6 |
3 | 32599961 | 37.5 | 5120 | 64 qam | 5 |
4 | 39399979 | 37.5 | 5120 | 64 qam | 4 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
Nothing new on the Network log
