on 13-09-2022 14:22
Hello all,
I am repeatedly suffering from broadband cut-outs of the service. This can be anything from 2 seconds to 2 mins. I have reset all equipment and this seems to improve things for about 24hrs, then it returns. This is a broadband issue, not WiFi as I am not using the hub for WiFi.
1 | 138750000 | 0.5 | 37 | 256 qam | 1 |
2 | 146750000 | 0 | 37 | 256 qam | 2 |
3 | 154750000 | 0 | 36 | 256 qam | 3 |
4 | 162750000 | 0 | 35 | 256 qam | 4 |
5 | 170750000 | -0.2 | 37 | 256 qam | 5 |
6 | 178750000 | -0.7 | 37 | 256 qam | 6 |
7 | 186750000 | -0.7 | 37 | 256 qam | 7 |
8 | 194750000 | -0.7 | 37 | 256 qam | 8 |
9 | 202750000 | -0.9 | 37 | 256 qam | 9 |
10 | 210750000 | -1.5 | 37 | 256 qam | 10 |
11 | 218750000 | -1.4 | 37 | 256 qam | 11 |
12 | 226750000 | -1.4 | 37 | 256 qam | 12 |
13 | 234750000 | -1.5 | 37 | 256 qam | 13 |
14 | 242750000 | -1.7 | 37 | 256 qam | 14 |
15 | 250750000 | -0.9 | 37 | 256 qam | 15 |
16 | 258750000 | -0.7 | 37 | 256 qam | 16 |
17 | 266750000 | -1.5 | 37 | 256 qam | 17 |
18 | 274750000 | -0.5 | 37 | 256 qam | 18 |
19 | 282750000 | 0 | 38 | 256 qam | 19 |
20 | 290750000 | -0.9 | 37 | 256 qam | 20 |
21 | 298750000 | 0.2 | 38 | 256 qam | 21 |
22 | 306750000 | 0 | 37 | 256 qam | 22 |
23 | 314750000 | -0.2 | 37 | 256 qam | 23 |
24 | 322750000 | 0 | 37 | 256 qam | 24 |
1 | Locked | 37 | 18430476 | 10245010 |
2 | Locked | 37.6 | 7026697 | 2229546 |
3 | Locked | 36.6 | 13433521 | 4490707 |
4 | Locked | 35.9 | 19912100 | 11264763 |
5 | Locked | 37.3 | 2546230 | 1300265 |
6 | Locked | 37 | 15660733 | 5861547 |
7 | Locked | 37.3 | 9757955 | 1750598 |
8 | Locked | 37.3 | 860217 | 62314 |
9 | Locked | 37.6 | 707675 | 52353 |
10 | Locked | 37.6 | 546602 | 19405 |
11 | Locked | 37.3 | 436928 | 8352 |
12 | Locked | 37.6 | 575287 | 37417 |
13 | Locked | 37.6 | 568339 | 35968 |
14 | Locked | 37.6 | 325209 | 5830 |
15 | Locked | 37.6 | 158315 | 2988 |
16 | Locked | 37.6 | 228505 | 10237 |
17 | Locked | 37.6 | 507960 | 63338 |
18 | Locked | 37.6 | 356058 | 26029 |
19 | Locked | 38.6 | 85589 | 3321 |
20 | Locked | 37.9 | 80405 | 1441 |
21 | Locked | 38.6 | 204590 | 12907 |
22 | Locked | 37.6 | 141412 | 9243 |
23 | Locked | 37.3 | 35434 | 1044 |
24 | Locked | 37.3 | 46870 | 1185 |
on 13-09-2022 14:23
1 | 60300195 | 41.8 | 5120 | 16 qam | 1 |
2 | 39399932 | 41.5 | 5120 | 16 qam | 4 |
3 | 46200228 | 41.8 | 5120 | 16 qam | 3 |
4 | 53700572 | 41.8 | 5120 | 16 qam | 2 |
1 | ATDMA | 0 | 0 | 280 | 0 |
2 | ATDMA | 0 | 0 | 107 | 0 |
3 | ATDMA | 0 | 0 | 93 | 0 |
4 | ATDMA | 0 | 0 | 154 | 0 |
13/09/2022 13:20:26 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/09/2022 13:20:23 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/09/2022 13:20:14 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/09/2022 13:20:14 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/09/2022 13:20:6 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/09/2022 13:16:25 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/09/2022 13:13:47 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/09/2022 13:04:6 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/09/2022 13:02:26 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/09/2022 13:02:18 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/09/2022 13:01:36 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/09/2022 12:34:55 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/09/2022 12:33:43 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/09/2022 12:05:37 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/09/2022 12:05:36 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/09/2022 12:03:28 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/09/2022 12:03:19 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/09/2022 11:50:24 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/09/2022 11:50:21 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/09/2022 11:50:1 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 13-09-2022 15:01
on 13-09-2022 15:09
Thanks John. Your first paragraph is exactly what I did previously and the issue resolved for a day or so before returning. However, I did not check the settings so I will try that again and see if I can log the errors reappearing. Thanks
on 15-09-2022 15:29
Hey NK212, thank you for reaching out and I am sorry to see you are having some issues with your connection.
Has the advice you have been given helped at all, or is the connection still cutting out?
Please do let me know. Thanks
Matt - Forum Team
New around here?
on 15-09-2022 16:51
Hello Matt,
I have followed advice above and still having issues - currently monitoring when PostRS errors return as suggested.
Please see below BQM - router was reset this morning at 9am which is the red block there.
on 18-09-2022 08:53
Hi there @NK212, thanks for reaching out to us.
I'm sorry to hear about the cutting broadband.
I have checked the system and I can see that there is an outage in the area caused by an SNR fault - Signal to Noise Ratio, i.e. a faulty cable on the network.
The estimated repair time for this area fault is scheduled for the 22nd September by around midday.
We apologise for any inconvenience caused. We'll check back after that date to see how the BQM and broadband quality is.
Kind regards.
